valve cover paint
Login | |
valve cover paint - 6/13/2007 7:28:02 PM
k_dogg70
Just was wondering about painting my valve cover. it is currently red but i wanted to paint it a light blue. What are some of the steps and maybe some reccommendations for removing the old paint and applying the new coat. The factory red paint is a thick coat with like specs in it. Is it possible to duplicate that but with blue? Does it need to be primed? Best method for removing old layer? Heat rating for the paint? anyother suggestions and experiences, thanks
RE: valve cover paint - 6/13/2007 7:42:38 PM
Sigracer10
use a scraper or a really rough sandpaper to get the old paint off. and make sure its completely clean before any painting. make sure you use high heat paint, and I don't know if they make it, but get some high heat clear if you can. You can get it up at o'reilly or auto zone, they have them that are for engine blocks and that should be fine for the heat of the valve cover. I didn't prime mine and it came out fine.
RE: valve cover paint - 6/13/2007 8:08:57 PM
danomatic93
Joined: 10/9/2006 From: Milwaukee, WI Status: offline
whoa whoa, just use heavy duty paint remover, autozone has something called aircraft remover that gets the paint off in minutes, literally. I have heard through the grapevine that it is not necessary to get hi-temp paint for the valve cover, although I use hi-temp when I do mine, just in case. I use duplicolor's caliper paint because I can paint the calipers, drums, and the valve cover all the same color at the same time. Follow the instructions. Also, if you plan on removing the valve cover, I highly reccommend getting a new valve cover gasket, valve cover bolt grommets, and spark plug seals (they normally come as a set)
_____________________________
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm For Sale Thread: http://www.hondacivicforum.com/m_558867/mpage_1/key_/tm.htm#559090 Bob Saget!
RE: valve cover paint - 6/13/2007 10:13:55 PM
Masonn
look in the DIY section, there is a whole DIY on painting the valve cover, with step by step instructions, with pics too
quote:
ORIGINAL: Gene J This forum does not condone street racing in any form. I'm sure a moderator will be along shortly to flame you for your indiscretion. Shame on you! quote:
ORIGINAL: Forty04 Gene....stop
RE: valve cover paint - 6/13/2007 10:31:12 PM
Roadkillboy0
i used brake cleaner man! that stuff is awesome!
My Stock Exhaust
RE: valve cover paint - 6/15/2007 8:58:30 PM
k_dogg70
The factory paint is powder coated ( i assume that is the proper term) it is thick gritty with bumps in the paint. How can u duplicate that but with blue color. thanks for the suggestions
RE: valve cover paint - 6/16/2007 11:27:30 AM
reaper2022
are you sure the factory isn't a wrinkle-coat paint? The paint on it will seem really bumpy and "wrinkly"... I'm going to eventually paint mine gold wrinkle-coat. Unfortunately, I've only ever seen red and black wrinkle-coat paints. So what I'm going to do is get black wrinkle-coat, paint it with that, and then paint the newly-wrinkled cover gold. You could do the same thing with blue. Anyway, I've heard that you don't really need to use high-heat temp (when you think about it, the valve cover never really gets all that hot), but I like to just as a little safety precaution. You'll want to sand off the factory paint (or use paint stripper or brake cleaner), then make sure everything is nice and dry. Now, if you want the lettering to stay silver, the easiest thing is to sand it now. After it's sanded to the point where you blind yourself when the glare catches you just right, put some chapstick over the lettering. After the chapstick is on, you can paint the cover like you'd paint anything else. Once the paint is dry, wipe away the chapstick to reveal the still beautifully sanded letters. You'll want to let the paint cure for however long the can says to let it cure for. Otherwise, the paint tends to do funny things. Also, I recommend Dupli-Color engine enamel; it's never failed me no matter what I paint with it, whether it be a valve cover, various tie-downs, brake calipers, interior trim, etc lol
94 civic ex 01 Mustang v6 01 cbr600 F4i
