Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 06-20-2007, 05:46 PM
zatozim zatozim is offline
Default noobie with a questoion
My girlfriend has a black 2001 honda civic LX sedan and she's been getting into the tunner cars. I wanna pick up somenew wheels(15-16 inch)for her but i dont know what would fit? Can anyone help me out with some suggestions?
Sponsored Links
Old 06-20-2007, 05:52 PM
civicexracer civicexracer is offline
Default RE: noobie with a questoion
pretty much any 15-16" wheel with a 4x100 bolt pattern.
__________________
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
Old 06-21-2007, 05:21 AM
Kommando Kommando is offline
Quote:
ORIGINAL: zatozim
Go to www.tirerack.com and enter the vehicle info. Then shop for a package. They'll set you up with a package that fits and you can decide whether or not to buy tires and wheels with those specs from them or elsewhere.
16s look nice and still ride ok. 17s start to ride a bit harsh and look better with a drop. 15s give good ride and are generally cheaper, but you get more sidewall deflection corneringand they don't achieve quite the samelow-profile stance. I'd go with 16s for a good compromise. Save the stock rims for winter tires if you get bad snow.
__________________
'00 VP silver-metallic 4dr (AC, auto, and 4 little wheels that go faster than any sane person should)
"At 75MPH it gets twice the MPG that my '95 2.5L 4cyl/5spd YJ w/31s gets at 55MPH."
Old 06-22-2007, 07:56 PM
phsballer123 phsballer123 is offline
that tirerack.com link is pretty dope man, thanks for that input
__________________
Once you go si, you never go back!
Old 06-22-2007, 11:29 PM
conceptualpolymer conceptualpolymer is offline
Tirerack and Discount tire have good selections, but after searching and calling both, I found that the only lightweightwheels at the Rack are $230+ each. Discount Tire has only heavyweights - at least only stuff that's heavier than 14 lbs or so.
You really have to look elsewhere to get lightweight wheels, since the last thing you should do is buy wheels that are heavier than the factory ones. Your ride and acceleration will suffer.
So take a look at this place for some lightweight Rotas that don't cost aywhere near $200 each. Many are available in Royal colors (polished lip).
http://www.jaydm.com/wheels.htm
__________________
1997 CX 5-speed
Eibach springs and shocks
Magnaflow cat-back
AEM V2 intake
16-inch Black Racing Pro wheels
Pillar Pod/tach/clock, Magnaflow and V2 install:
http://www.conceptualpolymer.com/honda_corner.htm
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
