Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
What's the best way to clean your engine bay?
  Printable Version
Honda Civic Forums >> Your Ride >> Detailing >> What's the best way to clean your engine bay? Page: [1]
Login
Message << Older Topic   Newer Topic >>
What's the best way to clean your engine bay? - 6/25/2007 5:35:49 AM
TIcivic00
Status: offline
TIcivic00's photo gallery
What's the best way to clean your engine bay I've heard of powerwashing it but I'm affraid I'll ruin the engine and get stuff wet thats not suppose to.  So if anyone out there knows a better way to clean it or stuff that I should cover up if I do powerwash it please let me know.
_____________________________
Post #: 1
RE: What's the best way to clean your engine bay? - 6/25/2007 6:33:34 AM
txedomask433
Status: offline
Cover your air intake system, sparkplugs and all electrical components. I just use a can of EngineBrite (which can be found at any auto store) and low pressure water to rinse it off. I then finish off w/ soapy water and a rag to get at the places which are hard to reach. Takes alot of time, but it's worth it and alot safer then high pressure water.
(in reply to TIcivic00)
Post #: 2
RE: What's the best way to clean your engine bay? - 6/25/2007 7:47:04 AM
Fiirkan
Status: offline
Fiirkan's photo gallery
http://www.hondacivicforum.com/m_94879/tm.htm try searching around first
(in reply to txedomask433)
Post #: 3
RE: What's the best way to clean your engine bay? - 6/25/2007 8:05:33 AM
matts
Status: offline
yeah, pressure washing will yield better results, but if you're the least bit nervous about it don't do it.  you can screw up pretty easily.
use some aluminum foil around the electrical connections, air intake, or any place you think doesn't need to get wet.  seran wrap will probably do the trick too
you can use a engine cleaner that's designed for the job and follow the directions, but any mild degreaser will do the job.  don't be afraid to get a stiff bristle brush (not a wire brush, just a firm soft bristle) after the non-painted areas, on the painted areas use a rag.
after you're done washing it off start the motor and let it run for a few minutes, that will help with drying.  or if you have a leaf blower or a shop vac that will blow air too those work just as well if not better.  when it's dry spray it down with a protectant of some type (i.e. armor all).  and when the protectant has soaked in wipe up all the puddles and spots left behind.
they actually make an engine protectant that you spray on and leave on.  it's a long term wax (or long term till you wash it with degreaser again, or eventually wears off).
if you have one of those portable fabric steamers they work wonders too.  you can buy them at bed, bath, and beyond for like $50 (i think)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
