Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
O2 Simulator Installed
  Printable Version
Honda Civic >> Your Ride >> Header, Intake, & Exhaust >> O2 Simulator Installed Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
O2 Simulator Installed - 6/27/2007 6:59:35 PM
FlipHKD720
Status: offline
FlipHKD720's photo gallery
So finally got my o2 simulator installed, could be a DIY if you wanted, but it was fairly straight forward. I snipped the o2 sensor wires and re-routed them to the simulator. Green to black (ground to ground), black to red (12V to 12V) and then Purple to white (signal wires). Unfortunately, still have a CEL  the 4th wire of the sensor the sensor heater wire, which i left just snipped, so now i'm pulling a code 65, which is telling me the sensor heater is broken  so i have to order a resistor to fool the ECU into thinking the heater is working properly  so still limpin', and this sh*t isnt even worth it since i'm gonna be OBD1 once the boost is complete. ANYWAY! heres a pic of it, tried to install it as clean as i could, might look a little haggard here but its actually really nice looking, the simulator lights up with a blinking ble LED when its working properly, so  that looks pretty nice as well  so all in all the simulator worked great, now time for a heater resistor
_____________________________
Post #: 1
RE: O2 Simulator Installed - 6/27/2007 7:47:30 PM
my05civic
Status: offline
my05civic's photo gallery
shouldn't have used wire caps. wire caps are used for house installation only.  the reason behind this is a house doesn't vibrate and your car does.... A LOT.  as a result, those are eventually gonna come off.  when that happens, you'll have to redo the wiring. i suggest you get a crimper and put the wires together with butt splices (lol at the retarded name of the splice)
(in reply to FlipHKD720)
Post #: 2
RE: O2 Simulator Installed - 6/27/2007 11:19:16 PM
danomatic93
Status: offline
danomatic93's photo gallery
plus water will get in there and corrode the wiring. For applications like this, I suggest using heat shrink tubing: http://en.wikipedia.org/wiki/Heat-shrink_tubing
You can get it at Menards in the electrial dept.
OR, better yet... ...you can get butt splices that have heat shrink ends!!! Those are my favorite!!!
http://www.wiringproducts.com/?target=dept_47.html&gclid=CJjunryV_owCFR6AWAodxDungg
You can also get these are Menards or some auto parts store have them!!
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm
For Sale Thread: http://www.hondacivicforum.com/m_558867/mpage_1/key_/tm.htm#559090
Bob Saget!
(in reply to my05civic)
Post #: 3
RE: O2 Simulator Installed - 6/28/2007 6:21:58 AM
Roto
Status: offline
Roto's photo gallery
resistors are found at radio shack...
PM me if you would like custom made vinyl stickers, magnetics, poster, or banners.
(in reply to danomatic93)
Post #: 4
RE: O2 Simulator Installed - 6/28/2007 7:33:02 AM
my05civic
Status: offline
with my foglights, i had to extend a wire.  the wire was in the cabin, and as i result, i only crimped the butt splice and didn't bother anymore with the heat shrink
Post #: 5
RE: O2 Simulator Installed - 6/28/2007 9:06:50 AM
FlipHKD720
Status: offline
alright, i think we've got a heat shrinker/tubing around here somewhere, i'll do that, thanks for hte advice guys
Post #: 6
RE: O2 Simulator Installed - 6/28/2007 12:56:56 PM
Remmy
Status: offline
Remmy's photo gallery
You werent supposed to cut those wires. I told you that before.
Post #: 7
RE: O2 Simulator Installed - 6/28/2007 2:50:39 PM
FlipHKD720
Status: offline
^ it was too late when you said that, i had already extended the wires, but now that i have the simulator they needed to be cut anyway
EDIT: and how would i have wired the simulator without cutting the wires??
< Message edited by FlipHKD720 -- 6/28/2007 2:53:34 PM >
(in reply to Remmy)
Post #: 8
RE: O2 Simulator Installed - 6/28/2007 3:35:11 PM
addiction2bass
Status: offline
addiction2bass's photo gallery
you could always look into the extension cable from a DX header swap....
i cannt remember what company sold them with the header tho.... ya might be able to find just the wires.... i tried extending my O2 wires before and it just didnt work :( instant CEL light :( but that was cause my header was for a DX and not a EX... so i had to drill and weld a O2 bung in the header in the stock location and plug the other o2 bung in the header and then cut the extended wires off and soldered the wires back together and now with the O2 where it should be it works again... with no CEL light ;)
not sure why your moven around... BUT just try to put it close to the stock location.... simply drill into the piping and buy a weldin O2bung from a exaust shop and have the bung welded inplace ;)
Post #: 9
RE: O2 Simulator Installed - 6/28/2007 4:19:20 PM
FlipHKD720
Status: offline
i'm runnin an ebay highflow cat/test pipe, so my secondary sensor would throw a CEL anyway. All i need now is the resistor for the heater wire and i'll be all set on CEL's. Also, at the very least i'll put some silicone sealant insdie all of hte caps to seal moisture and hold hte cap on better, or else i'll just shrink wrap them.
Gene i know they sell resistors at hardware stores, but the this is what i'm gonna get:
http://cgi.ebay.com/ebaymotors/O2-Heater-Simulator-For-Use-With-O2-Sensor-Simulators_W0QQcmdZViewItemQQcategoryZ46097QQihZ012QQitemZ220112340621QQrdZ1QQsspagenameZWD1V
little more than a little tiny resistor  although thats what i thought it would be before i saw an acutal pic
(in reply to addiction2bass)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic Forums >> Your Ride >> Header, Intake, & Exhaust
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414248
remmy11161
fiirkan10517
mill$civic8471
marty8273
mxs8006
fliphkd7207714
nail i3unny7705
sacicons7675
addiction2ba7375
New Vendors
K&N Engineering, Inc.
