Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-10-2005, 05:56 PM
boarder102586 boarder102586 is offline
Default 1992 Honda Civic Auto-Manual Conversion
I have a 1992 Honda Civic Ex Automatic and i also have a parts 1992 honda civic lx manual. I want to swap the auto for the 5 spd but i'm not sure how to go about it. I'm also looking for a new clutch. Does anyone know if i have to change the cv axle's. I need a lot of help
thanx
tim
Sponsored Links
Old 03-10-2005, 08:06 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
Default RE: 1992 Honda Civic Auto-Manual Conversion
post needs to be posted in the transmission section. but to answer your question,
parts list
92-00 5spd tranny
92-00 shift linkages (d-series exc. del sol)
92-00 pedal assembly(or choose to use only the clutch pedal and cut down the brake pedal)
clutch master with resevoir
hyd. master lines(lines from clutch master cyl to slave cyl.)
slave cyl
92-00 front transmission mount and bracket(auto will not work)
92-95 5spd ecu
your factory automatic axles WILL work with the 5spd conversion. ive done this many times and IMO well worth the effort.
__________________
Old 03-15-2005, 11:58 AM
Amanda Amanda is offline
I moved it to the correct section...
~Amanda
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
