RE: oil fill plug?
There is a fill hole on the bottom part of the tranny I think 17mm if I remember right. The book says to fill until it will drain back out same hole. The problem with that is it's on the side so a regular funnel won't work. It says to use a syringe, or I imagine a flexible small type funnel would work dropped down from the top of the engine. I used a rubber hose duct taped to the funnel. It isn't too bad to get to from under the car. [:@]
__________________
wendy
91 civic hatch
aledo, IL
