Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 07-29-2007, 07:39 PM
EightyNineDX EightyNineDX is offline
My Garage
Default Throttle Position Sensor removal/install
Where abouts is it located and is it easy to remove/install?
__________________
1989 Honda Civic DX Hatchback
Sponsored Links
Old 07-29-2007, 10:54 PM
SovXietday SovXietday is offline
My Garage
Send a message via AIM to SovXietday
Default RE: Throttle Position Sensor removal/install
Built into the throttle body, you'll need to buy whole TB.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 07-30-2007, 08:41 AM
Forty04 Forty04 is offline
Administrator
My Garage
Quote:
ORIGINAL: SovXietday
PSH, thats the EASY way to do it
You can swap the TPS by taking a hack saw, and cutting into the head of the screws holding it in (yes, they really are screws). Just cut a notch into it big enough for a flat head screwdriver, then use that to spint them out.
Have a multimeter on hand for the reinstall though, because it will need to be re-calibrated.
Also let me know if you need a new TPS, I think I have two of them sitting in the garage somewhere
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Old 07-30-2007, 04:30 PM
My Garage
I have to buy a whole new throttle body?! Holy crap man!
__________________
Old 07-31-2007, 04:48 AM
Administrator
My Garage
Quote:
ORIGINAL: EightyNineDX
wtf?! Did you even read my post?
__________________
Old 07-31-2007, 11:03 AM
My Garage
Sure did .. wasnt too keen on takin a hack saw to my engine. Looks like i might have to tho
__________________
Old 07-31-2007, 12:03 PM
Administrator
My Garage
LOL, you don't cut anything on the engine. If you take a good luck at your TPS, you'll see what looks like a rivit on each end of it. Those are just little dome-headed screws. You cut into that dome so that it looks like a flat head screw, then use a screw driver to take it out. Takes about 5 minutes and doesn't do any damage to the actual motor
__________________
Old 07-31-2007, 12:20 PM
mk378 mk378 is offline
My Garage
The TPS is supposed to be "permanently" part of the TB according to Honda, so it stays in calibration. They use security screws with heads that break off so they can't be removed. You're just cutting new slots in those screws so you can remove them and throw them away, then use regular screws to attach the new TPS.
Old 07-31-2007, 02:15 PM
My Garage
Hmm, not bad! I'll get right on it. Now, since they are not supposed to be separated, will i be able to buy just a TPS or will i have to buy the whole setup with the throttle?
__________________
Old 08-01-2007, 05:03 AM
Administrator
My Garage
finding only a TPS might be tough, but like I said, I should have two if you're interested in buying one
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
