RE: Transmission Flush and total amount of ATF fluid.
DONT DO IT, you will just have problems. your trans (seals mostly)are used to pumping thick dirty fluid through the chambers and when you flush or even change your fluid it just causes problems. ive heard that if a car gets a full flush every 20k its good but if it goes even 50k your better off just fillin it when its low and dont touch it otherwise.
__________________
85 300zx N/A AT
94 Teg LS AT
94 Civic EX with an identity crisis
