RE: Hey I need help ASAP
Well i hope I can help you. I did I 97 civic swap to b16. The throttle cable if it is to short just between the throttle body and where the throttle cable gets tightened you can modify the cable and pull out the wire farther back cut away the housing be sure not to cut the wire and pull the wire through. then put some sort of protection over it. The wiring I really doubt is plug and play call up rywire they worked great for me no trouble codes. Your stock hubs are fine but you need te matching axles maybe hasport. I hope this helps even though it seems to be a month and a half late. by the way the b16 engineswapis awesome so I hope the gsr motor will do you well.
__________________
1997 Honda civic dx
engine swap b16a DOHC VTEC stage 3 clutch fidanza flywheel
k&n intake
dc sports 4-1 header
high flow cat
cat back
lowering springs/ strut tower bar
95 SiR Rear drum to disk brake conversion
hasport motor mounts
