new exhaust, less HP?
I just took off the fart can that I purchased the car with and replaced it with custom 2.5" piping and muffler.
Before I put it on I could chirp second, I tried to do it today with the new exhaust and no dice. Did the new exhaust effect my torque that much? or I just need to add the I/H to my E? any info would help, I got some money to spend I just want to know what to spend it on. |
RE: new exhaust, less HP?
with 2.5, you probably did.
is 2.5" too big? (sorry bout the thread jack) cuz i have an 02 and i want a megan catback, but its 2.5 inch piping, and if i lose horsepower then thats gay
i as well as other usually say, 2.25" TOPS, its just not worth it to go any bigger
Normally 2.25 is good for mild engine work like i/h/e. If you are running a lot of nitrous then you might get away with 2.5 or if you are turbocharged then 3 is good. I think a lot of ppl with built n/a d series still run 2.25
Forty said his Megan Drift Spec which is 2.5" worked perfect for both N/A and F/I, i know i lost a little bit of torque with my 2.25" piping, i used to be able to chirp into 2nd and now i cant at all, it kinda sucks [&:]but top end feels good :)
can you get the drift spec in 2.25" piping?
I dont' think so... I'm almost sure it only comes with 2.5"
i have stock piping and it's good enough for my 100HP civic.
Probably just moved the torque curve- that may be why you can't chirp it (not that that is a great indicator of performance gains).
G-tech said I gained 7hp with my 2.5" when I was NA, but the margin of error there is probably pretty high. I did gain 3 tenths with just the additionof the cat-back though. |
| All times are GMT -8. The time now is 07:43 AM. |
