Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 08-08-2007, 12:15 AM
Chaos Chaos is offline
My Garage
Default Wiring Question
Im just wondering, most HUs only have a single or switchable RCA preamp out. If I have say, 3 amps, is there any advantage trying to find a HU that has 3 RCA outputs, or just use the one for the subs amp, and use the other method (its name eludes me) with all four wires going into the amp, for the other two amps. Basicly, does running RCA from HU to amp offer any noticable advantage over just speaker wires HU to amp?
__________________
Ride together, Die together.
-Tears shed in training saves blood shed in the battlefield-
Sponsored Links
Old 08-08-2007, 12:28 AM
ej6buddy's Avatar
ej6buddy ej6buddy is offline
My Garage
Default RE: Wiring Question
??? um, do you mean is there an advantage to running front and rear amps instead of just using the sup pre outs?
__________________
Old 08-08-2007, 07:56 AM
mk378 mk378 is offline
My Garage
Once you'reabove the $100-$150price class, it's common for a HU to have front, rear, and sub RCA outs.A line-levelRCA connection should be used when possible because there will be less background noise and distortion than using the speaker outs. But if you really really like a HU's other features except it doesn't have all the line outs, you can get acceptable sound driving the front and rearamps with the speaker outs.
Old 08-08-2007, 08:04 AM
jeff948594 jeff948594 is offline
My Garage
like mk378 only your bottom of the line hu's have the single imput, if you are amping your speakers and a sub you clearly already dropped some money on the amps (or atleast they cost somebody some money) so dont cheap out on the hu, because there are certain features that they have that you may not think of everyday but they make a world of difference. good example is eclipses rca level output, any eclipse deck above the base ecd-1000 has atleast 5volt preouts (up to 8volts on higher models) so it gives the amps a stronger signal, where as most hu's dont even advertise there preout level but i believe it is somewhere between .8v-3v, . so if you are looking for a good hu i think the eclipse ecd-2000 is about 200
__________________
85 300zx N/A AT
94 Teg LS AT
94 Civic EX with an identity crisis
Old 08-15-2007, 04:39 PM
My Garage
Cheers guys, my new HU is on the way. My next question is, will 4gauge wire support 900W RMS over the 5m or so from battery to boot? Or am I gonna have to look at 2 gauge? Ive had sites claim it will hold the 900W fine, and some claiming its only rated up to 600W. Any input, experience, opinions please?
__________________
Old 08-15-2007, 04:44 PM
civicduty96's Avatar
civicduty96 civicduty96 is offline
My Garage
4 ga is fine for 900 watts
__________________
96 civic..t25 turbo...FMIC
jdm sir ll swap..stage 2 ACT clutch
OBX LSD...hondata s300
AEM wide band...ACL race main and rod bearings
JE forged pistons and rings
Eagle H-beam rods...cometic head gasket
GM 3bar map sensor..GM boost seloni
Old 08-15-2007, 06:25 PM
addiction2bass addiction2bass is offline
My Garage
ya 4gauge suports up to 1200watts. so it should be fine.
if you can run preamp rcas then id do it that way..... preamps have a beter signal. they also use low power.... which is another reason why they sound beter... they dont pull as much juice from the radios power source.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
