RE: Removal of stock radio?
\No problem! Step one... remove the belly pan under the steering wheel, and then proceed to remove the glove box. The belly pan has 3 screws and one clip (which is next to and behind the dimmer controls) and the glove box has 2 screws under it. Remove those 2 screws with the glove box clipped in (or it will fall on your face). The remove the center belly pan. There are 4 screws holding that in. You have to remove the belly pan and glove box in order to remove the center belly pan. Once you remove the screws, gently pull the center belly pan off and unclip the 12v outlet. Then go under the dash of the radio, you will remove two demagnetized screws, once that is done get a puddy knife and a towel, pry out the radio bezel. The whole bezel will come out so dont worry, just unclip the Hazerd lights, AC, and what ever other wire is connected. Now unclip the radio. Your done. When you go to put it back in, keep in mind to check eveything is connected again. The radio bezel snaps right back in with a little palm slam.
__________________
