Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 03-19-2005, 05:47 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
Default wet and dry nitrous
whats the difference between 'wet' and 'dry' nitrous oxide systems?
Sponsored Links
Old 03-19-2005, 06:46 PM
Patrick Patrick is offline
Administrator
Default RE: wet and dry nitrous
wet shot meant that your nitrous line is spliced in with your fuel line, thus when the nitrous is injected, it has a small amount of gasoline mixed with it...it helps to prevent from extreme leaning conditions which are naturally caused by using a nos mixture....dry shot is simply the nitrous gas, injected alone....
dry shot kits are much easier to install, due to the lack of having to splice into your fuel line...also with a wet shot system, in the case of a V6....you have to fuel rails to deal with...but the wet shot kit is MUCH safer...if there is such a thing as a safe nitrous kit...i have driven/raced a bottled car..and it is quite a bit of fun...until it blows up...[&o]
__________________
Old 03-19-2005, 07:02 PM
wow thx uve really boosted my confidence in the stuff :P
Old 03-19-2005, 07:04 PM
Administrator
i mean..for instance...we bolted a wet kit 55 shot onto a car, and it was a bit of a pain to install it...but it went from running 16.50s to 15.40s...on an engine with 160k on it...and it ran for a whole race season...spraying on the street and track...but 55 isnt a very heavy shot...
__________________
Old 03-19-2005, 08:59 PM
sacicons sacicons is offline
on the stock motor in my car, we ran a 50 shot dry, and went from a 17.2 to a 15.4. but after awhile, N2O gets old, and youre gonna want a turbo or SC.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 03-20-2005, 08:44 AM
Administrator
wow..thats a GREAT jump for a 50 dry shot...the bottle was the only change you made??
__________________
Old 03-20-2005, 11:50 AM
yeah, it had a short ram too, but it had it before and after, so the only change was the bottle between runs.
__________________
Quote:
ORIGINAL: Forty04
Old 03-21-2005, 09:44 AM
turbob18c1 turbob18c1 is offline
Send a message via AIM to turbob18c1
the wet mixes the nitrous with fuel and is allot safer to use b/c of the extra fuel. the dry is just nitrous. when used w/o any richining and a high shot (100) then ur asking for trouble
__________________
keep on boosting!
Old 03-21-2005, 02:55 PM
Kappa22 Kappa22 is offline
Direct port is always preferrable to either of the other two, but is also quite a bit more expensive...
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
