Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 08-23-2007, 05:50 PM
b3nSoNx b3nSoNx is offline
Default will swapping the transmission of my car make it run the same as a car with original 5speed tranny?
some people have told me that it wont run the same, but maybe that just depends on how well work was done?
Sponsored Links
Old 08-23-2007, 05:57 PM
addiction2bass addiction2bass is offline
Default RE: will swapping the transmission of my car make it run the same as a car with original 5speed tra
what you mean? swaping a 5speed with a automatic tranny or swaping a clutch setup?
if your swaping in a automatic..... performance will suck.LOL if swaping from auto to stick it will feel alot quicker!
but your motor will run the same either way.... its just geting the power to the ground that will make it feel differently.
__________________
96dx silver 5speed project.
99ex black automatic.
Old 08-23-2007, 06:59 PM
swaping an auto to a manual
then i plan to get a new flywheel and clutch too
Old 08-23-2007, 08:21 PM
ltkenbo ltkenbo is offline
You mean like a performance flywheel and clutch because transmissions already have those, lol.
__________________
Old 08-23-2007, 08:23 PM
yea, i meant like aftermarket ones, i wont be keeping the stock ones
Old 08-24-2007, 01:33 AM
well from a auto to manual it will feel alot beter! and automatic doesnt have theh clutch setup.. it has a torque converter which is the main reason performance blows....
just do your research on it..... ive thought about doing it but thiers just so many little things that im probably beter off just buying a manual car....
but if you can find a donor car go for it!
__________________
Old 08-24-2007, 03:17 PM
SovXietday SovXietday is offline
Send a message via AIM to SovXietday
You need a manual ECU other than that the transmission is simply a torque multiplier, it does not affect engine function what so ever, only engine output.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 08-26-2007, 11:35 AM
06coupe 06coupe is offline
yeah both transmissions will still have the same engine power so its only thing changing is the fact that you got to shift it yourself.
Old 09-03-2007, 01:34 AM
jwsimons jwsimons is offline
Quote:
ORIGINAL: 06coupe
nice theory, however slightly flawed.. yes, the same power, but gear ratiosmake all the difference in the world, not to mention tighter gear ratios, thats why so many of us have made the swap to manual
__________________
getting there is half the fun, do it yourself
Old 09-07-2007, 08:09 PM
speed_o speed_o is offline
Send a message via AIM to speed_o
I know you'll like the feel of a manual more. At least I would!
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
