Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-22-2005, 12:27 PM
wohnny wohnny is offline
My Garage
Default Question about driving style - Clutch up Fast or Slow?
Does it cause less wear and tear on the clutch to lift it slowly when engaging it into gear or by engaging it quickly (ie: life the clutch pedal up quick)...and get the clutch pedal out as quick as possible..(particularly in 2nd and 3rd gear)
Logic would say that since you're being soft and gentle on your clutch, and your car is accelerating smoother, a slow and steady lifting of the clutch that would be a better way to extend the life of your clutch..but then riding your clutch wears out the clutch disc..so wouldn't you want to spend as little time with your clutch pedal "partially depressed"..
I would assume that people who "clutch-out" quickly will have more wear and tear on the engine(but not necessarily the clutch) as it naturally causes a more aggresive driving style..any? For those who have had clutches forever, is there a particular way that you drive? I've had mine for 150K and drive it right in the middle but I'll gladly lean towards one way or the other if it'll save me from a clutch job..
This is a nitpicky question, but any way I can adjust my driving style to extend the life of the car helps..
Sponsored Links
Old 03-22-2005, 02:40 PM
Kappa22 Kappa22 is offline
My Garage
Default RE: Question about driving style - Clutch up Fast or Slow?
It does depend on your driving style, but the best solution is a fairly quick release (not a drop) coupled with a reasonable accelerator level, one that will prevent bogging, but won't kick like the dickens. Riding the clutch is NEVER a good thing. Period.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Remmy Remmy is offline
Administrator
My Garage
The more you ride your clutch the worse its going to get... some people have their foot on the clutch half way down all damn day. The quicker you do it the less damage. Now unless youve got the pedal to the metal of course its going to damage the clutch more no matter what way you do it.
__________________
Old 03-26-2005, 02:30 AM
94VTECoupe 94VTECoupe is offline
My Garage
I can shift quickly AND smoothly at the same exact time. What I do is quickly let the clutch out (let it out, not pop it out) but I wait until the clutch is engaged all the way before giving it too much throttle.
Old 03-26-2005, 03:04 AM
D16z6's Avatar
D16z6 D16z6 is offline
My Garage
I put my clutch pedal to the metal and put it into neutral when im slowing down for any reason. By doing this i guess im killing my clutch.
About how long does a clutch last??
__________________
A
Old 03-26-2005, 02:01 PM
sacicons sacicons is offline
My Garage
my stock one went 120k, so this isnt really that much to worry about. a new one cost me like 140, and i installed it myself.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 03-27-2005, 12:03 AM
D16z6's Avatar
My Garage
hey sac since u install a clutch before how hard is it????
__________________
A
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
