Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-23-2005, 11:01 AM
nino nino is offline
Default HELP...problem with trans
i have a 98 civic lx with a 5speed ,and there is noise coming out of the gearbox when i push th e clutch in it makes almost like a winding ,grinding,ratteling type sound even in neutral it makes the noise the only time it doesnt make the noise is when i push the clutch in and when i first start up the car and the engine is cold i already changed the fluid in tranny i thaught maybe that would help and its still the same
__________________
apc coil overs-kyb struts-CAI-
Sponsored Links
Old 03-23-2005, 11:00 PM
sacicons sacicons is offline
Default RE: HELP...problem with trans
sounds like maybe a throwout bearing. does it only go away if you press the pedal all the way down, or does it go away with just a little pressure?
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 03-24-2005, 09:24 PM
thanks for responding, the tranny makes the noise when i press the clutch all the way down in neutral and in gear but when its in gear and i let off the clutch it is alot louder.
__________________
Old 03-27-2005, 10:45 PM
bump still need help
__________________
Old 03-27-2005, 11:51 PM
ohbiskits ohbiskits is offline
Send a message via AIM to ohbiskits
id say its the throw out bearing...but u say its louder in gear with the clutch out?
Old 03-28-2005, 01:44 PM
jwsimons jwsimons is offline
im having the same problem, exactly..more load louder it gets? kinda sounds like a kid with cards in his spokes? but deeper? i've tried changing fluid also, and i keep checking to b certain its full ( cuz its sounds dry), i was wondering if somehow the starter might be not pulling back far enough, or something is a different pitch.. is this the car you just did the 4 to 5 speed? thats what i have done also. i used a crx '91 in my '88 hatch. if we both have same symptoms from the same upgrade we have overlooked something obvious.. did you install new clutch at same time? i did. new throw out bearing also. if i find anything i'll let you know.. please do same.. i want that chatter gone
__________________
getting there is half the fun, do it yourself
Old 03-28-2005, 01:46 PM
duh!!!! for some reason i thought this thread was started by ohbiskits... so ignor the reference q's. in prior post
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
