Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 09-13-2007, 08:53 PM
knoklu knoklu is offline
Default wiring 2 amps
yea i want too know if i can wire 2 amps together, 1 a 1000 watt amp and the other a 600 watt.there both kenwood and will be pushin 2 12s, kicker comps vrs(comin in the mail)
wich i think will be a good power supply for em. and how do you guys think the comps vr are. thanks
__________________
Sponsored Links
Old 09-14-2007, 05:42 AM
BX_Civic BX_Civic is offline
Send a message via AIM to BX_Civic
Default RE: wiring 2 amps
im not a master installer but when i have wired up two amps that are that strong i have done the following:
Run a 4 or even better 0 gauge power cable to the tunrk. Then get one of those distribution blocks that you can have multiple power leads come off of and be clean. Then run a 4 gauge power cable to each amp. Ground each amp seperatley and make sure your grounds are very good and the shorter the cable the better.
Other than that everything is the same just now you have two amps to deal with.
__________________
Sitting on 17's not even sure what kind they are..
Little bump in the Trunk but nothing to special..
Pic's of the Car Below
http://obi1kanobi.com/Images/Car/
Old 09-14-2007, 07:10 AM
Sigracer10's Avatar
Sigracer10 Sigracer10 is offline
i think he wants to run the signal together to both subs so that its basically one amp, not just hook then both up at the same time. ive seen it done, but i have no idea how
__________________
Old 09-14-2007, 08:14 AM
mk378 mk378 is offline
You cannot combine multiple amps to one speaker (unless you have a dual voice coil sub, then you could connect one amp to each coil but the amps have to be identical).
Connect each amp only directly to one speaker and then use a RCA Y cable to split the signal going into the amps. Typically head units have "left" and "right" subwoofer outputs but I think it will be the same signal so you pull them apart and run one to each amp and don't need a Y adapter then.
Old 09-14-2007, 11:56 AM
civicduty96 civicduty96 is offline
you can hook 2 amps together it's called strapping .... not all amps can be strapped though...check with kenwood to find out for sure.
if your 1000 watt amp is a true 1000 watts i'd just use that one... escpecillay if it's a common chamber box ..it'll be plenty for 2 cvr's.... and it's better to use a common ground
so you have less of a chance of creating a ground loop...... when you have resistance between 2 componets you can create engine whine...
__________________
96 civic..t25 turbo...FMIC
jdm sir ll swap..stage 2 ACT clutch
OBX LSD...hondata s300
AEM wide band...ACL race main and rod bearings
JE forged pistons and rings
Eagle H-beam rods...cometic head gasket
GM 3bar map sensor..GM boost seloni
Old 09-14-2007, 03:50 PM
Sigracer10's Avatar
its stRapping, just makin sure nobody gets confused.
but if they are capable of it, they won't work together cuz they have to be the same model to be strapped together.
as for the rest just refer to the above stated
__________________
Old 09-14-2007, 05:35 PM
o ok, well i just wanted to have enough power and im buying an amp of some guys thread KAC-7252 the model if you wanna look to see if its a true 1000 watts and do you think my q logic bandpass box is worth keepin or get a ported thanks, sry bout the bold just noticedlol
__________________
Old 09-14-2007, 05:56 PM
i cant type very good ....thanks sigracer......the manuals on it's way
__________________
Old 09-15-2007, 11:03 AM
KarTuneMan KarTuneMan is offline
When you "strap" or however, and whatever you wish to cal it. Typically the amps are identical.
__________________
Quit your complaining, if your stupid..... your stupid.
It's not MY fault! Blame your parents.
Old 09-15-2007, 12:01 PM
Sigracer10's Avatar
Quote:
ORIGINAL: knoklu
no its not a true 1000, just a max 1000. the true wattage is only about 250x2 rms at 2 ohm. and those subs are 400 rms each. so if you want to push those subs all the way, you are gonna need a bigger amp. plus i personally hate kenwood. used to havethe exact one you are looking atand it always overheated and shut off with the gain up only at about half way\
and civicduty thanks again man, cant wait to see what kind of random modules they make.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
