Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 07-12-2004, 04:46 PM
outlawzz23 outlawzz23 is offline
Default HOW TO SHIFT USING NOS
I JUST HAD MY NOS KIT INSTALL. HE PUT IT THAT I DONT HAVE TO USE THE BUTTON I JUST STEP ON THE GAS. BUT WHAT HAS ME CONFUSE IS THAT I WAS TOLD NOT TO USE NOS ON FIRST GEAR. BUT IF THE NOS IS ACTIVATED WHEN I HIT THE GAS WHAT DO I DO?
Sponsored Links
Old 07-12-2004, 04:55 PM
lilol89crx lilol89crx is offline
Send a message via AIM to lilol89crx Send a message via Yahoo to lilol89crx
Default RE: HOW TO SHIFT USING NOS
he's saying not to use it through first as traction will be a major concern as well as low rpm engine damage from the strain of the nitrous burst. its kinda tricky if you have no button to push, your going to have to learn to stay out of nitrous in 1st by not using full throttle. its something you have to practice with. as far as shifting, do your very best to shift before the rev limit/fuel cut as major engine damage can occur within that split second. also while on nitrous you can actually run a faster et by shifting sooner than you would without it as you can use the full potential of the tq curve while nitrous is activated. my experience with nitrous was with a zex kit, which used the tps voltage to activate. i would just launch at 4k and hold the pedal about 3/4 the way until i got into 2nd, then i would floor it.
__________________
89 crx sold.....91 hatch new project for turbo ls
<br />90 crx dx-daily beater
<br />04 suzuki gsxr750-sunny day beater
<br />83 rx7-pos sittin in the yard
01 yamaha r6 stunt bike-pos that i dont care about
Old 07-13-2004, 08:49 AM
polo708 polo708 is offline
Send a message via AIM to polo708
wow, I never knew you could run it without a button???[sm=smiley3.gif] when does the nitrous kick in and how?? Thats pretty cool.
__________________
-brian
Old 07-13-2004, 02:09 PM
NTX NTX is offline
My kit was set up the same way. They should have added an arming switch. Run like normal, then arm it when you get to the point at which you want to use it.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 07-13-2004, 02:39 PM
green98lxsedan green98lxsedan is offline
Quote:
ORIGINAL: polo708
its a switch on the floor behind the gas pedal and when you mash the pedal down it activates the switch. they had one on this badass truck on TRUCKS. they put nitrous and propane injection.
__________________
gone but not forgotten 98 civic lx sedan
RIP 3/23/05
current garage
04 nissan armada le
01mustang gt
blown, intercooled, and cammed
04 acura tl
98 4runner
Old 07-14-2004, 03:12 PM
MY SWITCH IS IN MY GLOVE CONPARTMENT I JUST TURN IT ON AND FROM WHAT I HAVE BEEN READING JUST STEP ON IT.
Old 07-14-2004, 03:44 PM
NTX NTX is offline
My arming switch is in the box too. What I do is get up to the speed I want, then arm and go. Thats the only way you can run the first few gears hard while stayin off the juice....
__________________
Old 07-14-2004, 10:30 PM
im with that guy^^^^^^^ anyhow as far as nitrous activation..... zex goes by tps voltage at WOT.....nx,nos and others rely on a micro switch either placed behind the gas pedel or at the TB.
__________________
Old 07-15-2004, 04:55 PM
YEA WHAT IAM GOING TO DO IS JUST TURN THE NITROUS WHEN I BUILD UP SPEED. THAT MIGHT BE THE SAFEST WAY.
Old 07-15-2004, 05:03 PM
NTX NTX is offline
you can also have a push button installed and remove the throttle switch.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
