Autocross and Road Course Racing For sanctioned SCCA Solo events, HPDE, track days, and more
AutoX Newbie needs help with Setup
Old Sep 30, 2007 | 06:30 PM
mxs's Avatar
mxs
Default RE: AutoX Newbie needs help with Setup
ORIGINAL: keithisjonesn
-I have the yellow adjustable Koni Sports Shocks. They have adjustable rings around the shock depending on suspension setup. I have raised the rear ring up to put the coilover perch higher and allow the shock more travel. The Front shock I left in the middle(stock setting).
that's not what "adjustable" means!
you can adjust the amount of rebound in the shocks, by twisting on the top of the shock using the white **** that you get when you buy them...
Old Oct 1, 2007 | 07:16 AM
keithisjonesn's Avatar
Yes I'm aware of the white **** to change my firmness or "rebound" as noted in my original post. I just added the info about the ring placement because I left it out of my first post.
Maybe going back to springs and getting rid of the coilovers might be a step in the right direction. Increasing the rear spring rate because YES the car does love to understeer.
Old Oct 1, 2007 | 07:45 AM
mybrokenblinker's Avatar
take off the front sway and see what happens...it's just an idea for helping you play with setup without spending any money.... it should make you understeer less.
Old Oct 1, 2007 | 12:27 PM
Taking OFF the front sway bar. That's the first I've heard of doing that but won't that increase body roll?
I raised my car up about an inch all around. Mainly to get the front higher off the ground and see if I can get a better response from the shocks/coilovers.
[IMG]local://upfiles/18344/5D571133D92545FB915055F87492785B.jpg[/IMG]
[IMG]local://upfiles/18344/15DE74A4C0804CC8B5E7CB807E77E7DE.jpg[/IMG]
[IMG]local://upfiles/18344/E6D39DDA6F5B46C380642C5DC0301B06.jpg[/IMG]
Old Oct 1, 2007 | 01:14 PM
mxs's Avatar
mxs
Read the stickies in this forum and the suspension forum.
I think your front swaybar is smaller than stock. That's good. You need a bigger rear bar though. Have you had an alignment lately?
Even after 7 events you will still need lots more practice to beat the experienced drivers. And better tires!
Old Oct 1, 2007 | 03:15 PM
The front swaybar is bigger than stock and the rear is a 19mm. And yes to the alignment. And I totally agree with you on the better tires. Any suggestions on a tire that is street/track? How about BFs G-Force T/A's?
Old Oct 1, 2007 | 05:01 PM
mxs's Avatar
mxs
you don't want a bigger front bar, you want a bigger rear bar.
Falken Azenis are going to be the best tires to start with. But they will never be competitive in a class where others can run 275 wide Hoosiers [8D]
Old Oct 1, 2007 | 05:37 PM
That's the way it is. The rear bar is 19mm and the front bar is much smaller but I might try removing it, but after I try running with higher air pressures and my new ride height. I'm just afraid that body roll will increase if I remove the front sway bar.
Old Oct 1, 2007 | 05:57 PM
mxs's Avatar
mxs
??? you already said the front bar was bigger than stock, and stock is like 24mm or so.
just disconnect one end and see if it changes things. you don't have to totally remove it.
if you are still getting body roll, you need stiffer springs.
Old Oct 1, 2007 | 06:45 PM
you will get more body roll obviously by removing the bar, but it will help correct your imbalanced understeer.
