Power Steering Fluid Level
Login | |
Power Steering Fluid Level - 3/31/2005 1:22:04 PM
Custom24
Hi just a quick simple question. I've just bought a S/H Honda Civic 2003 Insprire S VTEC, standard UK spec. Normally, on a car with power steering, I would expect to see a steering fluid reservoir and I would check the level in this regularly. However, on mine, there does not seem to be such a reservoir. Although the manual does mention that the power steering fluid level should be checked regularly, it does not say how to check it or where to look. Any ideas? Thanks Mark
RE: Power Steering Fluid Level - 3/31/2005 1:48:24 PM
Gvaski
If your Vtec's the same as mine, On the right hand side of the engine is a cylinder about the size of a tin can with a small filler cap on top, just next to the windshield washer reservoir, that's the poiwer steering fluid, should only need topping up at service unless you get a steering problem.
