i have a 99 ex with the 99 si engine swap.....its to me the best looking civic and the engine runs smooth.....the best engine for modification reasons i think....
just for clarity, the si didnt have vtec until 92. also, only the 99-00 SIs have the dohc vtec(USDM)and its 160hp at the flywheel, the jdm motors have slightly higher compression and they have the 170hp. the 92-95 si only has 125hp sohc vtec, but its still a good platform to build with.
__________________
the 92 and up EXs came with vtec and had comparable performance to the 92-95 SIs, but none of the sohc vtecs can hang with the dohc vtec in the 99-00 si.
P.S. the 92-95 also offered a VX hatchback which was equipped with vtec-e which is designed for fuel efficiency not for power, it actually has less power than the non-vtec in the dx
__________________
