Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 10-09-2007, 09:46 PM
zhmendak zhmendak is offline
My Garage
Default Vibration
I have a problem.
Everytime I brake at speeds higher than 20MPH my steering wheel vibrates like crazy. I have no power steering, it a 95 civic DX. I replaced rotors and pads two times already and the problemstill exists. I am starting to think it's either my steering column or my rack and pinion. Any suggestiones?
__________________
Ukranian's_drive_civics!
Sponsored Links
Old 10-09-2007, 11:56 PM
Everyday Getaway Everyday Getaway is offline
My Garage
Default RE: Vibration
When's the last time you had an allignment?
Old 10-10-2007, 05:48 AM
My Garage
Last year. But this problem hasbeen goin on since I bought the car.
__________________
Old 10-10-2007, 12:01 PM
My Garage
It sounds like it's a problem with your wheel hub then... I'm not totally sure. I'd take it to a shop to just get it checked out, they usually don't charge more than $25 just to look at it and identify the problem
Old 10-10-2007, 01:34 PM
Sigracer10's Avatar
Sigracer10 Sigracer10 is offline
My Garage
might be warped rotors. they may need to be machined, or maybe even replaced. just take it to a brake shop to get it checked out
__________________
Old 10-10-2007, 01:38 PM
gocoho's Avatar
gocoho gocoho is offline
My Garage
- how are the tires? - is it only when braking?
Old 10-15-2007, 06:58 AM
My Garage
yeah,
It's only when I brake, maybee its the struts.
__________________
Old 10-15-2007, 01:30 PM
Cyphen Cyphen is offline
My Garage
Are you driving for awhile and then this happens? or does it happen ALL THE TIME EVEN when you first start driving... if its after awhile then your breaks/rotors are no good you have glazed rotors vibration/shaking of steering wheel means your applying a hot brake to a hot rotor, your not going to get any stoping power, dangerous have your rotors replaced and brake pads i had that same problem i put Brembo/Akebono brake pads pricey but worth my life
__________________
93 Civic Coupe
Mid built B16a2/Stainless steel D/C Headers/AEM Intake/No Name exhuast
Old 10-15-2007, 03:08 PM
My Garage
Cyphen!
Did your steering wheel shaked when you applied the brakes? I already replaced my rotors like 2 times and the problem is still there. If I buy brembo rotors and quality pads will my program go away? Where did you get yours?
__________________
Old 10-15-2007, 04:06 PM
My Garage
i got mine from my freind i had MAD SHAKES felt like there was a 4.0 earth quake in my steering wheel i got $80 dollar rotors BRembos (dont get cross drilled and slotted) <-- brembo doesnt warranty them anymore cause they warp they make regular rotors um as for the akebono break pads you can find them on google just type akebono brake pad it some what expensive but yes its worth your life. for a couple extra bucks
On personal note i dont trust anyone else with my life but Akebono+brembo
__________________
93 Civic Coupe
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
