HondaCivicForum.com
-   -   amps (https://www.hondacivicforum.com/forum/audio-visual-electronics-10/amps-4259/)
speedstream Apr 2, 2005 09:39 AM
amps
i am looking to buy 2 sony 12" p5s and i was wondering what to look for when buying an amp for them. i want good power with a good price tag. help!!!!
Pete Apr 2, 2005 01:42 PM
RE: amps
go on ebay and get a rockford....look for a 2004 model.......theyll be a bit more than other amps but welllll worth it.
speedstream Apr 2, 2005 08:59 PM
RE: amps
how many watts are power enough to push these subs hard!!! 1300w max 380 rms
Pete Apr 2, 2005 10:44 PM
RE: amps
well those subs are ****.....so whatever wattage they give u.......cuz it in half......a rockford 500 watt amp would prolly chew those subs up and spit em out.......go over 1000 watts and those subs will hate you......get a rockford amp and get rid of those subs.....nice subs that can handle power id recommend Infinity Perfects or Alpine Type R's......get dual 4 ohm subs so u can have a 2 ohm load to the amp to get the most possible power.
97civicturbo Apr 5, 2005 02:29 PM
RE: amps
I agree those subs aren't very good, but if you are going to keep them, dont' buy an expensive amp because you won't need that much power. Get a rockford fosgate 300 and you'll have plenty of power, they are only like 140 dollars new on ebay. Plus if you upgrade your subs you can still use that amp later.
Roost3r Apr 5, 2005 06:40 PM
RE: amps
if you buy those subs, wire them into ur back speckers..thats about all the power they can handle
bigindian869 Apr 5, 2005 08:01 PM
RE: amps
yeah, I agree with everyone else, you wont be able to put much power to those sony's and even if you give them power they can handle it will sound shallow and crappy. Alpine's are prob the best bang for the buck. I don't think they make type r's anymore, I think type s is the new model. I heard the type s is a little bit cleaner, but isn't nearly as durable and loud.
speedstream Apr 5, 2005 08:52 PM
RE: amps
the type-x is the new one. it is made of carbon fiber (i think) and it is loud as hell
Roost3r Apr 6, 2005 12:48 AM
RE: amps
pg is better:D
Remmy Apr 6, 2005 08:24 AM
RE: amps
DL is better'er:D
