xenocron chipped ecu has arrived, need some guidance
hi, my ecu turned up today andi was expecting there to be a plug in point for a pc lead but there isnt?, also there is a spare chip, one of them should have a a base map loaded on with crome compatible software, how would i know (by running the car)?? how do they plug there laptop in then if there is no plug?
Thanks,
RE: xenocron chipped ecu has arrived, need some guidance
if you need a datalogging cable, you need to specifically order it. Are you doing your own tuning? if you're getting someone else to tune it, they'll probably bring their own equipment anyway
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Typically, they will use their own ECU to do all the tuning. Then, once completely, burn the final maps to the chip, plug it into your ECU, and send you on your way.
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
