DYNO
OK what does DYNO stand for and where can i get one done???? like preferrably in TN, lol
RE: DYNO
its short for dynamometer
any local tuner shop should be able to direct you to the closest one. |
RE: DYNO
and you have gone to one right???... if so what did they do?
RE: DYNO
yeah... a few times. They put your car on a treadmill kinda thing and hook it up to a computer. It reads your HP and torque in a chart form... showing levels at every RPM so that you can see where your powerband is. theya also set it up to check your air/fuel ratio to make sure you arent running too lean. It also measures emissions and stuff.
For instance...I will have my supercharger on very soon. After I get it put on I will do a dyno run with the stock airbox, then a run with the cold air intake. This way I can see exactly how much power the CAI gives me and at what RPMs the increase in power is at. If you do alot of modding then its a great help because it lets you "tune" your stuff. Makes sure its all running at its maximum output. |
RE: DYNO
ok cool, thanx polo lol, with 666 posts...
polo708 4th Gear Member Posts: 666 |
| All times are GMT -8. The time now is 04:49 PM. |
