RE: installing my new deck
When taking the head unit out make sure you remove the cage, also make sure you put the new head unit cage in as well, else it will not fit. Apart from that, everything should just slot in to place. When I put my new head unit in I didnt disconnect the battery, but it probably is safer if you disconnect it.
__________________
Honda Civic 1.4i 16 valve
