Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 10-26-2007, 07:29 AM
redcivicrippa98 redcivicrippa98 is offline
My Garage
Default do i need a camber kit???
I just bought a set of TEIN S-Tech lowering springs, 1.9"drop in front and 1.7" drop in the rear. Will i need a camber kit so my tires wont wear hard on the inside corners? or are the camber kits just for extreme drops like 3"-4"? right now i have 205/40/ZR17's so i know i will be tucking them a little bit, i just wanna buy new tires every 3 months. any info would be great thanks!
__________________
1998 Civic EK4
T-56, HKS Front mount
JDM K20 forged internals
100 Wet shot
Sponsored Links
Old 10-26-2007, 07:32 AM
95civic1.6l 95civic1.6l is offline
My Garage
Default RE: do i need a camber kit???
if u are lowerin your civic a camber kit wouldn't hurt. It is true it will stop the corners from wearing but you have an oversized tire dont u?
__________________
ARE YOU IN NEW ENGLAND, Check out the List, we want to have a meet!
http://www.hondacivicforum.com/m_418142/tm.htm
YOU Drink! YOU DRIVE! YOU LOSE!!!!!
Old 10-26-2007, 07:41 AM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
NO, read the stickies, and get an alignment when you're done
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 10-26-2007, 05:35 PM
KarTuneMan KarTuneMan is offline
My Garage
Align what..... ? do a toe adjustment?
__________________
Quit your complaining, if your stupid..... your stupid.
It's not MY fault! Blame your parents.
Old 10-26-2007, 05:36 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Toe is the only thing that CAN be adjusted from the factory on our cars.
__________________
Old 10-27-2007, 05:10 PM
conceptualpolymer conceptualpolymer is offline
My Garage
Eibach seems to think that they are necessary.....
Quote:
After the installation of either an Eibach Pro-Kit or Sportline spring set, a vehicles' alignment should always be checked. Once lowered, a wheel's camber may become "increasingly negative," meaning the top of the tire is angled inward (toward the center of the vehicle). While some "negative" camber aids in improving traction and road adhesion, too much can result in peculiar handling and accelerated tire wear.
Eibach offers a complete range of alignment kits which offer a simple, affordable solution to adjust "negative camber." These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications but they also allow the experienced chassis tuner to utilize the increased adjustment range to "dial-in" a performance alignment that uses negative camber to maximize a chassis' potential. Turn-in becomes more precise and handling increasingly crisp and predictable. High-speed stability is also enhanced making an alignment kit from Eibach almost a necessity for the serious performance tuner.
__________________
1997 CX 5-speed
Eibach springs and shocks
Magnaflow cat-back
AEM V2 intake
16-inch Black Racing Pro wheels
Pillar Pod/tach/clock, Magnaflow and V2 install:
http://www.conceptualpolymer.com/honda_corner.htm
Old 10-27-2007, 09:22 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
and they are trying to get you to buy their kit. read it again, they even say at the end "almost a necessity."
I certainly believe they have a purpose, but they are not a necessity for a 1.8" drop
__________________
Old 10-27-2007, 11:31 PM
My Garage
Well, I guess it's only a necessity if you want your tires to wear evenly. The alignment shop owner told me that most of the "extreme"-type lowering springs he's installed required a "kit". I'll be having the "moderate" lowering springs (Eibach) installed in a couple of weeks. With only 1.5-inches of drop, no kit should be required.
__________________
1997 CX 5-speed
Magnaflow cat-back
AEM V2 intake
Old 10-28-2007, 07:15 AM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Quote:
ORIGINAL: conceptualpolymer
This isn't true and I don't know why nobody ever believes me when I say this. TOE wrecks your tires, not camber; toe can be adjusted on our cars from the factory.
Link from the stickies in this forum: http://www.heeltoeauto.com/httech/Ya...num=1162587420
Quote:
I have had over a dozen hondas, all lowered, and most lowered past 2". I have never had a camber kit on ANY of my cars. The ONLY car that I had a problem with tires with was my 94 accord which I had never aligned. Go figure.
__________________
Old 10-28-2007, 03:39 PM
My Garage
The type of wear from lowring without changing the camber will likely be excessive wear on the insides of the tires - something most people don't notice until it's too late. I find it hard to believe that the factory camber setting can allow for a 2-inch drop. All the Civics I see on the road with an extreme drop have tires that are obviously camber-challenged. (top of tire is tilted toward the center of the car)
__________________
1997 CX 5-speed
Magnaflow cat-back
AEM V2 intake
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
