Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 04-06-2005, 09:40 AM
setjr12 setjr12 is offline
My Garage
Default Transmission fluid
I have a 98 Honda civic, with a d16y8 engine. I am wondering how do i check my transmission fluid.
Sponsored Links
Old 04-06-2005, 09:59 AM
ohbiskits ohbiskits is offline
My Garage
Send a message via AIM to ohbiskits
Default RE: Transmission fluid
since u said fluid im assuming its an auto?
Old 04-06-2005, 10:08 AM
My Garage
no its a 5 speed.
Old 04-06-2005, 03:06 PM
Forty04 Forty04 is offline
Administrator
My Garage
manuals have gear oil, not tranny fluid.
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Old 04-06-2005, 10:16 PM
sacicons sacicons is offline
My Garage
actually, its not gear oil either. its engine oil. 10w-30. there is a 17mm plug on the side of the transmission on the passenger side. undo that and see if the level is close to the hole. actually, just change it. its 2 qts of 10w-30. you just jack up the car a little, slide a pan under the hole to catch the oil, then use a ratchet with no socket to open the drain plug that is located just below the fill hole. let i tall drain out, then close that up, and fill the thing back up with fresh oil. 2 qts fills it perfectly, but its tough to get the oil in. youll need a long funnel with a flexible end. its easy though, it takes me more time to let the oil drain than everything else does.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 04-07-2005, 03:07 AM
My Garage
yea thats what i was gunna say...just change it...
Old 04-07-2005, 11:19 AM
Blackhatch124 Blackhatch124 is offline
My Garage
Send a message via AIM to Blackhatch124
you use 10w30 in your tranny sacicons? i didnt think you could do that i run royal purple.
Old 04-09-2005, 07:02 PM
My Garage
well, its supposed to be 10-30. i use mobil1 synthetic. im not sure about the long term effects, but it seems like it would be better. and i havent had any problems yet.
__________________
Quote:
ORIGINAL: Forty04
Old 04-09-2005, 07:31 PM
finalimpact finalimpact is offline
My Garage
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
i personally run cheap advance auto 10-30 and never had a problem. i find it easier to remove the reverse light switch and use a long funnel and fill through there. ive seen some people who remove the starter, then remove the 19mm bolt right below the starter and fill there.
__________________
Old 04-09-2005, 08:04 PM
Kappa22 Kappa22 is offline
My Garage
Just use a long funnel and put a piece of heater hose on the end, then stick it in from the top and feed the hose into the filler hole...
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
