Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 04-08-2005, 09:55 AM
setjr12 setjr12 is offline
My Garage
Default Problem wiith the shifter.... HELP
I have a question when I am driving my 5 speed I can klet off the gas and push the stick and it will go into neutral, is my car supposed to do that or is my clutch or something messed up. If so then should i not do it anymore.
Sponsored Links
Old 04-08-2005, 10:24 AM
Blackhatch124 Blackhatch124 is offline
My Garage
Send a message via AIM to Blackhatch124
Default RE: Problem wiith the shifter.... HELP
what rpm's are you at when you do this? sometimes if you are at a high rpm the shifter will pop into neutral really easy.....how hard is it to get it into neutral?does it grind or make any weird noises?
Old 04-09-2005, 06:13 PM
sacicons sacicons is offline
My Garage
you probably shouldnt, but its not a huge deal. it COULD wear on the synchros a little bit faster than normal, because theres still a little torque being put to them as they slide out of place. but just dont do it a lot. sounds nomal though.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 04-11-2005, 08:46 AM
My Garage
When i do am able to do it I am at 4000 rpms or higher. It starts to make a grinding noise also. It is verty easy to put it into neutral.
Old 04-11-2005, 11:12 AM
ngoti 8tor ngoti 8tor is offline
My Garage
Are you putting it into neutral intentionally or accidentally?
Old 04-11-2005, 11:15 AM
Dan Dan is offline
My Garage
Griding noise usually = Not good. If you are intentically putting it into neutral I would stop. Or at least only do it very rarely.
__________________
faster, You must be!
Old 04-12-2005, 08:41 AM
My Garage
I put it in neutral intentionally.
Old 04-12-2005, 02:30 PM
My Garage
Can we ask why you intentionally put it into neutral while driving? If I were you, I'd stop doing it.
Old 04-12-2005, 02:37 PM
Kappa22 Kappa22 is offline
My Garage
Because compression braking is harder on your engine than you think.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 04-12-2005, 05:39 PM
StifflersMom's Avatar
StifflersMom StifflersMom is offline
HCF Village Idiot
My Garage
most of the time my car is in neutral and I usually take it out of gear w/o clutching. No grinding and it slips out without any force. To me this is just a driving habit and I don't see how this is killing anything
__________________
Gimme some love, shuga'
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
