I have a D15 SOHC motor and tranny for sale. The motor will need a rebuild, the valve seals and rings are going to need replaced. As far as I no, the motor does run, its just starting to act up in 1st, 3rd and 4th when you go to pick up, it spurts, and has a lack of pick up and go, same with power. does eat oil. Everything will go with the motor, all you will need to do is install the motor and drive away (once you rebuild or use for parts) the tranny is 5 speed and shifts through all 5 gears will no problems. You will also get the 5 Speed ECU.
Im asking $200 for all of it. Pick Up ONLY! Unless you pay FULL Frieght shipping. Item is located in Waynesboro PA 17268. PM is the best way to get ahold of me.
Sorry for the crappy picture, but thats all I have for now. You will get the intake with the motor.
