Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 11-19-2007, 12:26 PM
rcalimquim rcalimquim is offline
Default whats under your hood?
please post what are you running (tc/sc)kit or custom and how you like it.
i got a edelbrock turbo kit on my 97' civic ex. its great, instructions are pretty much walk through. I love the sound of the bov. Its a complete kit which is great also, dont have to get anything else besides a "missing link"(voltage clamp) to hide the boost from the map sensor.
Sponsored Links
Old 11-19-2007, 01:05 PM
gsumano gsumano is offline
Default RE: whats under your hood?
^^^ I have the same set up, even the same car year also lol [sm=icon_cheers.gif]
__________________
Turbo d16y8
gt28r @ 7psi
Old 11-20-2007, 09:25 AM
MY99SI MY99SI is offline
Send a message via AIM to MY99SI Send a message via Yahoo to MY99SI
i wouldnt go with a Missing link. the stock map sensor will be fine to 12 psi, after that, which incindentally envolves internal work, a GM 3 bar map can be used by splicing it into the factory harness
__________________
http://limaracing.myfastforum.org
Old 11-20-2007, 09:36 AM
Cyphen Cyphen is offline
Quote:
ORIGINAL: rcalimquim
I have a b16a2 with stainless steel dc headers, magnaflow exhaust.aem intake. Motor has been sleeved ported intake has been ported comp ratio changed, i belive 9:11 \
btw how much your turbo kit cost you around
Old 11-20-2007, 10:15 AM
Quote:
ORIGINAL: MY99SI
you have too if your are running the edelbrock kit on a 96-98 civic. If you don't, it would trow you a CEL and go into limp mode[&:] The other option is to run the edelbrock's voltage clamp which is around $80, so it's just cheaper to run a missing link
Quote:
ORIGINAL: Cyphen
brand new, they cost around $3,200-3,500. I got mine used in perfectly good condition for 1,200 locally.
__________________
Turbo d16y8
gt28r @ 7psi
Old 11-22-2007, 08:14 AM
SovXietday SovXietday is offline
Send a message via AIM to SovXietday
Oh boy.
D16Z6
Block: 75mm Vitara pistons, Eagle rods, new OEM bearings, ported oil pump.
Head: Zex 59300 cam, Zex Valve springs
Transmission
Stock 1-2, 1.346 3rd, 1.033 4th, .771 5th
OBX LSD, all new bearings.
Turbo setup:
CCfab ramhorn manifold
Garrett T3T04e 57trim .63AR Stage 3 wheel
3" downpipe 3" full exhaust
Tial 38mm Wastegate w/ dumptube
2.5" aluminum IC piping
12x24x3" PWR FMIC
Synapse Synchronic BOV
BLOX Intake Manifold
GM 3bar MAP sensor
APEXi AVCR boost controller
Hondata S300 - Tuned myself
Too much money in this car lol.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 11-22-2007, 10:26 AM
PNK SLP PNK SLP is offline
Send a message via AIM to PNK SLP
wow ^^^ thats a hella nice set up, car looks clean to, have uran it yet??
__________________
2000 civic SI-450+whp
To some people, a car is a car. But to people like us, its so much more than just a car. Its a gateway. Its our hiding spot. Its our comfort. Its an extension of ourselves
Old 11-22-2007, 04:44 PM
aryiman98civic aryiman98civic is offline
Asst. Admin
Send a message via AIM to aryiman98civic
let see what i have, i dont think it will be as good as sov's.
engine:
b16a2 swap
turbo set up:
turbonetics 60-1 turbo
fmax log mani
p28 chipped ecu with crome
dsm 450sw/ resistor box
3" downpipe to 2.5" cat back
255 walbro fuel pump
8 psi
i am getting a new clutch this winter so i will be up to 10 psi in the spring.
__________________
spooling on the b16!
Old 11-22-2007, 06:03 PM
im running a b18c1 bored to a 1.9
T3/T67HO Garrett Turbo
Tial 44mm Wastegate 2' Dump
15psi
peak performance Rods,
CP Pistons,
ARP Rod Bolts and Head Studs
PortFlow Port&Polish B16 head
Eibach Valve Springs
Peak Titanium Retainers
Act Extreme 6 Puck Clutch stage 3
Endyne Catch Can vv
Precision 1000cc Injectors
STR Fuel Rail with Fuel Pressure Regulator
3" Custom Down Pipe
3' Custom Exhaust with Black Apexi N1 no cats, no restrictors
__________________
Old 11-24-2007, 02:18 PM
Quote:
ORIGINAL: PNK SLP
Nope, this year was hell for me and cars lol. I had the engine in and running for 7 months but 2 accidents generally keep things from getting done.[:@]
Your car looks like it freaking moves, track times? If I ever come across the money I might build an SFWD car, we'll see though.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
