UPDATED:
Im parting out a 1995 acura integra rs. 5 speed.The following items listed below are the things i have left.. so if you are interested in any of the items, you can call me at 1626 466 7563 or at
h22a4typer@sbcglobal.net and thanks for looking...
DRIVER AND PASSENGER AXLES.
INTERMEDIATE SHAFT,HALF SHAFT. SOLD
POWERSTEERING PUMP.
POWERSTEERING HARD LINE.
POWERSTEERING PUMP BRACKET. SOLD
WINSHIELD WIPER ARMS AND BLADES.
PASSENGER REAR KNUCKLE ASSEMBLY.
REAR CALIPERS.
REAR E- BRAKE CABLE.
DRIVER AND PASSENGER DOOR PANELS BLACK/GRAY.
STEERING WHEEL IN BLACK.
IGNITION SWITCH,LOCK AND KEY. SOLD
SPEEDOMETER CLUSTER 5 SPEED 118K.
SPEEDOMETER TRIM.
DASHBOARD IN BLACK. SOLD
MASTER CLUTCH CYLINDER.
CLUTCH,BRAKE AND GAS PEDALS.
COPPER LINES FOR CLUTCH PEDAL FOR CONVERTING AUTO TO MANUAL.
FAN BLOWER.
REAR TAIL LIGHTS.
DRIVER AND PASSENGER POWER MIRRORS.
FRONT BRAKE CALIPERS.
REAR BUMPER REINFORCEMENT BAR.
FRONT BUMPER REINFORCEMENT BAR. SOLD
WIPER SWITCH.
BLINKER SWITCH.
STEERING COLUMN.
DRIVER DOOR MOLDING. SOLD
DRIVER AND PASSENGER DOOR INTERIOR DOOR HANDLES, IN BLACK. SOLD
FRONT SWAY BAR WITH ENDLINKS OEM.
REAR SWAY BAR.
FRONT DOOR SPEAKER COVERS IN BLACK.
PASSENGER DOOR WINDOW SWITCH IN BLACK.
DRIVERSIDE WINDOW REGULATOR AND MOTOR. SOLD MOTOR..
PASSENGER SIDE WINDOW REGULATOR AND MOTOR.
FRONT AND REAR SHOCKS.
OEM SPRINGS.
ALTERNATOR BRACKET.
DRIVERSIDE MOTOR MOUNT.
TRANSMISSION MOUNT 5 SPEED.
REAR T - BRACKET. SOLD
INTAKE MANIFOLD WITH SENSORS,AND INJECTORS. SOLD
SHIFT LINKAGE WITH SHIFTER. SOLD
REAR LOWER CONTROL ARMS.
CLOCK.
HAZARD BUTTON SWITCH.
DEFROST BUTTON SWITCH.
DIMMER BUTTON SWITCH.
GAS LID.
PASSENGER SIDE "A" PILLAR TRIM.
DRIVER AND PASSENGER DOOR SILLS IN BLACK.
FRONT AND REAR SEAT BELTS IN DARK GRAY. SOLD THE REAR...
REAR SEAT BELT BUCKLES IN BLACK.
HOOD STICK HOLDER.
E- BRAKE HANDLE IN BLACK.
REAR VIEW MIRROR.
DRIVERSIDE FENDER LINER.
