Rear (anti) sway bar and reinforcement
Old Dec 8, 2007 | 12:08 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: Rear (anti) sway bar and reinforcement
Full ASR kit for $340
http://cgi.ebay.com/ebaymotors/ASR-R...spagenameZWD1V
Full Beaks kit for $235
http://www.beaksproducts.com/EG_Quick_Swap.htm#
Progress Kit, well, I haven't found on, but contacted a vendor that claimed he had them, so time will tell.
So far I leaning towards Beaks because of the price but I have read that there are issues with the install. I have installed everything on my ca myself, but if ASR is that much easier to install, I'd be swayed (no pun intended, initially) to go for ASR.
Old Dec 8, 2007 | 03:01 PM
civicexracer's Avatar
the only problem with installing the Beaks kit i had was breaking the tack welded nuts that are on the inside of the subframe off. their just hard to reach unless u have a long chisel and a good hard blow with a hammer. that or an air hammer with a long chisel piece. im not 100% sure, but i do believe u'll have to do the same with the ASR kit because it uses very similar subframe brackets. something u may want to find out.
Old Dec 8, 2007 | 08:19 PM
mybrokenblinker's Avatar
just so you know, I have the ASR kit and it is AWESOME. I can post some pics for you if you want.
Old Dec 8, 2007 | 11:06 PM
June 2010 ROTM
shoot, go for it!
Old Dec 9, 2007 | 05:06 PM
Ok, I have to take the pictyures so I'll get them up as soon as I can
Old Dec 9, 2007 | 05:48 PM
here's my ASR kit hooked up, I got the black one to fly under the radar!
Old Dec 9, 2007 | 07:52 PM
mxs's Avatar
mxs
ITR bar and Beaks kit are probably the best bang for your buck.
Old Dec 10, 2007 | 10:02 AM
June 2010 ROTM
Here is the progress kits that were recommended to me:
$233 - 24mm, adjustable
http://www.neverenoughauto.com/index...roduct_id=1573
$179 - 22mm
http://www.neverenoughauto.com/index...roduct_id=1581
These both mount to the Shock/LCA bolt. I don't like that. So, what do yall think?
Thus far, I'm going with a Beaks kit...
Old Dec 10, 2007 | 10:07 AM
mxs's Avatar
mxs
ORIGINAL: danomatic93
do you have pictures of them installed?
Old Dec 10, 2007 | 10:10 AM
June 2010 ROTM
ORIGINAL: mxs
If you go to either of the links, click on the "Images" tab. The $179 sway bar has more pictures of it installed. It also looks like the exhaust would get hit all the time.
