I have a 2002 civic ex sedan. with stock tires and steelies. im looking at lowering it about 2.25 in the front and 2 in the back using skunk2 lowering springs. my question is has anyone lowerd this much on stock tires and rims, will it rub?
__________________
In my four door, you know what the means, i can fit more hoes.
i say do the drop, just get as close to the same size tires as stock. S-Techs give a slightly mellower drop, but still eliminate wheel gap, but if you want the bigger drop, i dont htink you'd have THAT much trouble. Can always roll the fenders like addiction did
maybe look into coilovers, so you can adjust it to the point right before it rubs or whatever.
ya i just thought about that as well..... get some adjustable coilovers and tweak yyour ride.... i think adjustables are the BETER WAY.... that you can completly level your ride out! for instance... my 94civics old drop springs was lower on one side about 1.5-2fingers on one side in the front, and not sure about the rear tho... dont have them on my ride anymore... but with adjustable coilovers you can set the car COMPLETLY LEVEL....
__________________
96dx silver 5speed project.
99ex black automatic.
after much reading, i know that using stock sturts with lowering springs is not recomended, but how bad is it REALLY? and what are some struts/or full coilovers that are good quality but i can find for a decent price?
__________________
Please read the stickies at the top of this forum -- all of this info is in there.
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
i have an '04 lx sedan and was debating the same thing when i first got the car. since i didn't have the $$ for full coilovers, i planned to install lowering springs and replace the oem struts later since they were still relatively new. deciding how low i wanted to drop it was the hardest part, i didnt want to go too low b/c i'd sacrifice ridequality and have to be EXTRA careful driving. i also didnt want to not lower it enough so when i put 18"s on it there wouldn't be a gap, and also so it'll look good w/ steelies. for $200 i could've got neuspeed race springs or the skunk2 springs(2.25f-2.0r), nice and low. my other option was goldline springs or tanabe/sustec springs (1.8"f&r). after extensive research i went with the tanabe's and i'm definitley satisfied. the drop was noticable, in and outside the car, and after driving on them for a few months they started to settle lowering it a tiny bit more. as far as camber, i didnt geta kit b/cthe 7th gen civics are different from the 5th & 6th. however, dpending how low you drop it you might need one. i do have some negative camber on my rear tires, but the time it takes for regular tires to wear and lowered car tires to wear isn't much of a difference. MOST IMPORTANTLY, MAKE SURE YOU GET A 4-WHEELALIGHNMENT ASAP AFTER YOU LOWER IT!!!!
__________________
'04 civic lx sedan
PIAA xtreme white plus headlamp bulbs
Tanabe/Sustec DF210 lowering springs
K&N typhoon short ram intake system
NGK IV iridium spark plugs
Neuspeed front upper strut tower bar
