Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 01-16-2008, 09:56 PM
00IntegraLS 00IntegraLS is offline
Default turbo plans in future, what to get done first?
I will be putting a turbo in my 2000 integra ls within the next year probably. What should I all get done to my engine first to make sure its as reliable a setup as possible? I'm going to get the Edelbrock kit that is meant for a stock setup, but there has to be some things I should do that will re-inforce the reliability.
Already know I should get ARP studs, and a stage 1 clutch.... but is there anything else that is highly recommended? reliability is huge for me since I use my car to deliver pizzas, although I may be done delivering pizzas by the time I get the turbo installed. like is there anything with cam gears, cams, pistons, whatever.... i plan on leaving it at the factory psi settings
Sponsored Links
Old 01-16-2008, 09:58 PM
FlipHKD720 FlipHKD720 is offline
Send a message via AIM to FlipHKD720
Default RE: turbo plans in future, what to get done first?
headstuds, new clutch, lower compression pistsons/new rings (if not replacing pistons/rings, do a Compression test before you try to boost, check the DIY about it), Eagle rods, Cometic headgasket, bigger fuel injectors/fuel pump, maybe rail too, then 2.5" - 3" exhaust.
and for more info about this, read the stickies.
__________________
Old 01-16-2008, 10:04 PM
well the edelbrock kit says that it comes with everything to upgrade the fuel system as well. and then also the mechanic thats installing it said that pistons wouldnt need to be replaced as long as I'm running at factory levels of psi. is this correct or should I do it anyways?
so basically its just headstuds, stage 1 clutch, eagle rods, diff. headgasket, and maybe pistons?
Old 01-16-2008, 10:13 PM
factory levels of PSI? What? There is no Civic that has any type of boost, no what PSI would he be talking about?
Lowered compression isn't totally necesarry (again, read the sticky about it), but it does make your car more reliable (but you do low-end torque because of the lower comp)
__________________
Old 01-16-2008, 10:19 PM
factory as in the the turbo. The kit is set up at the levels of psi that will work with a stock engine, and then if you want to up the psi then he recommended doing pistons and what not
Old 01-16-2008, 10:21 PM
gsumano gsumano is offline
Quote:
ORIGINAL: FlipHKD720
His talking about the factory set level on the edelbrock kit, which is at 7psi.
00integrals, no need for the eagle rods or pistons at stock boost level... All you really need is a new good clutch. The arp studs is a good idea to help prevent headlift on the long run and since you need to lift the head to installed them might as well installed a new headgasket (oem should be good enough).
Also, since the edelbrock downpipe doesn't come with a flex pipe, the turbo manifold can get crack in a few years. So, is a good idea to weld a flex pipe to the downpipe.
I'm not sure about the integra edelbrock kits, but for the civic one's, edelbrock forgot to but inclulded an oil restritor for the turbo , so it's a good idea to get one to prevent the oil seals from blowing up in the long run.
__________________
Turbo d16y8
gt28r @ 7psi
Old 01-16-2008, 10:25 PM
thank you for the help, so stage 1 clutch, arp head studs, and any new head gasket will work? Are you saying that when installing the turbo kit they have to take off the head to install the turbo or the head studs? Like would it be alrgiht if I got all this stuff done in March/April and then didnt get the turbo installed until August? or should I consider having it all done around the same time?
Old 01-16-2008, 10:30 PM
Quote:
ORIGINAL: 00IntegraLS
No need to take off the head for the turbo, but for the arp studs its recommend to take it off.
No need to worry about installing the arp studs and clutch before the turbo. For the clutch, I recommend an action 2ms or 2md clutch.
http://www.garage-life.com/Action_Clutch.html
__________________
Turbo d16y8
gt28r @ 7psi
Old 01-16-2008, 10:33 PM
if you install the turbo kit itself, theres no need to take apart the engine, the headstuds are when you'll need to take it apart a little bit. And the clutch/headstuds would be okay for installing now and waiting for hte turbo kit, but don't mess with anything fuel-related until the final install.
__________________
Old 01-17-2008, 05:46 AM
MY99SI MY99SI is offline
Send a message via AIM to MY99SI Send a message via Yahoo to MY99SI
thats not entirely true. there was an 80's honda city turbo.
__________________
http://limaracing.myfastforum.org
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
