Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Old 01-21-2008, 03:04 PM
zoom24 zoom24 is offline
My Garage
Default NEWBIE ON THE BLOCK
Ok im new in the block ... i have a 99 civic ex and I already started some modifications already.
I installed a generic short ram just to get the feel of it and now planning to install NGK plugs and wires,
grounding kit, and just recently purchased a full Megan exhaust...Now my question is, will it help at least
horsepowerwise if I install a SKUNK2 intake manifold and throttle body??? Any suggestions with this
issue?
__________________
Sponsored Links
Old 01-21-2008, 03:10 PM
Live_4it Live_4it is offline
My Garage
Default RE: NEWBIE ON THE BLOCK
I would go edelbrock over skunk2 for the intake manifold I've heard mixed things about the skunk2 intake mani. But yea you def would notice a difference nothing huge powerwise. just got to make sure that the intake manifold and the throttlebody have the same diameter hole. Or else you will lose power instead of gain.
For the amount of money those products will cost you, youminus well save up for a turbo kit. That will give the d16y8 more power in the long run.
Don't forget to research on here you will find most of the info you need.
__________________
Old 01-21-2008, 03:26 PM
My Garage
Thats a good advise thanks for the quick reply....I will keep that in mind but you know what? I might have forgotten
to post that I only have a 99 civic ex sohc type engine? Im not looking to power up the car like other guys have. Im just looking
to add a bit of power on it. Do you have any suggestion??? A friend of mine told me that it would be perfect if I can do an
engine swap... I know it would be great...But for now this is my direction, just to fix up this 99 civic ex sohc....any tips??
__________________
Old 01-21-2008, 03:36 PM
My Garage
A nice short shifter (B&M, skunk2 etc) and a header like dc-sports or megan racing would help make that car funner to drive. Also upgradeing the suspension will make you car even funner to drivearound turns and stuff. Front and rear strut bars are cheap and easy mods, one of the only products worth getting on ebay IMO. Name brands way overcharge.
But check out the suspension section for more info and the header, intake, exhaust... oh hell check them all out
__________________
Old 01-22-2008, 04:15 AM
Kommando Kommando is offline
My Garage
Quote:
ORIGINAL: zoom24
issue?
I'm big on retaining stock mileage, so I don't go the big-power route for performance gains. If you haven't done a header and a flow-thru cat, you'll probably notice more HP gain from those. You may actually even improve your MPG a little.
Then I'd work on the suspension and tires, if you're not cornering at over a g yet. Add some adjustable anti-swaybars, lower H-braces, a front upper 3-pt strutbrace, a rear upper strutbrace, and some UHP 205/45-16s on lightweight wheels like Rotas.
A short-throw shifter will quicken your shifts a bit too. Also consider a performance clutch, and possibly an LSD.
__________________
'00 VP silver-metallic 4dr (AC, auto, and 4 little wheels that go faster than any sane person should)
"At 75MPH it gets twice the MPG that my '95 2.5L 4cyl/5spd YJ w/31s gets at 55MPH."
Old 01-22-2008, 10:21 PM
My Garage
nice talk i appreciate the reply, yah im heading that direction with the headers. but i dont think i would pass the state inspection if i install a high flow cat. and also thank you for the tips regarding the strut... suspension im fine i dropped the car i think 2 inches and im looking in purchasing some wheels too.
__________________
Old 01-22-2008, 10:29 PM
My Garage
hey live 4 it did you got the valve cover painted or powder coat? coz its nice...and also i like the strut bars...is it hard to install them? coz im planning to install one on mine.
__________________
Old 01-23-2008, 12:11 AM
Civic Si 00 Civic Si 00 is offline
My Garage
here is a before the Dc Sportsheader went it
After......
__________________
Civic Si 2000
AEM short ram intake
AEM High flow fuel filter & Adujustable Cams
Magnaflow Exhaust and Magnaflow Cat
Eibach springs
HID Kit 8k Bulbs
Skunk2 shift knob
DC Sports headers ceramic 4-1
Old 01-23-2008, 05:19 AM
My04Civic's Avatar
My04Civic My04Civic is offline
Administrator
My Garage
strut bars are a sinch. and improve handling pretty well for how simple they are.
__________________
Old 01-23-2008, 01:46 PM
My Garage
are they hard to install? what are the process are far as installation???? coz im planning to get them (rear and front).
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
