Autocross questions
Login | |
RE: Autocross questions - 1/21/2008 6:58:29 PM
civicexracer
do they have a website? www.scca.com more specifically for autox: http://scca.com/hub.aspx?hub=3 is there one near San Jose California http://scca.com/divisions.aspx <click on the map to find regions near you. how old do you have to be need a valid drivers license, if under 18 u'll need to have a parental consent form filled out. http://www.scca.com/documents/Club%20Forms/MinorReleaseFormMS-L_W_Program.pdf are there certain car specifications just needs to pass tech inspection. its very simple and straight forward. they check: -wheels to make sure wheel bearings are good and lug nuts are tight -tires to make sure no cords are showing -interior/trunk for any loose items that could be dangerous -battery to make sure its held in securly with battery tie-down -blip the throttle to make sure it dosnt stick -check brake fluid reservoir and some other simple stuff.. what are the car classes class depends on what mods u have. most civics with basic engine(i/h/e) and suspension mods fit into Street Touring Sport(STS). read the scca rule book for HS, STS, SM, and DSP(i believe some modded civics run DSP, someone correct me if im wrong). http://www.scca.com/documents/Solo%20Rules/2008_Solo_Rules_2.pdf and anyother relative info thanks guys i dont think i would do it with my 03 lx but hopefully next year im praying for a project car depending on the rents just go out and have fun!! try not to go mod crazy thinking everything is going to make u faster because it really wont. the car is only as fast as the driver
_____________________________
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
RE: Autocross questions - 1/21/2008 7:01:58 PM
jpnolan
thanks a ton i just dont think i would do it because idk if my parents would let me besides the fact that i work 6 days a week but i will look into all the safety and try to come up with a way to talk them into it
BRING BACK ROTM PLEASE my for sale http://www.hondacivicforum.com/m_541152/mpage_1/key_/tm.htm#542402
RE: Autocross questions - 1/21/2008 7:14:42 PM
civicexracer
worst comes to worst, drag them out to an event just to watch. its a very safe environment, they take all the precautions necessary and follow the rules set by SCCA. its safer to run ur car at these events than driving a few miles to the event.
RE: Autocross questions - 1/21/2008 7:54:45 PM
jpnolan
i keep reading about a racing lisence do i need one of these? because it says its like 570 for the lisencing and like 1200 to rent a car? sorry for so many questions
RE: Autocross questions - 1/21/2008 7:59:52 PM
civicexracer
no racing license required to autox, just a valid drivers license. dont need to rent a car either since u'll be using ur own.
RE: Autocross questions - 1/21/2008 8:53:12 PM
mybrokenblinker
Check local autocrossing groups too that are non scca affiliated. The group i autox with is not scca but follows the same rules, but since they're not scca, the events are much cheaper.
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
