Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 01-23-2008, 11:41 AM
00IntegraLS 00IntegraLS is offline
My Garage
Default how much hp gain from turbo?
ok I have a 2000 integra ls, 140 hp stock. I am getting a Rev Hard stage II turbo kit... it says, and I quote, "Horsepower gains are usually in the 120hp range and gains for torque are about 285 ft/lbs" How much of this power is to the wheels?
heres the link http://www.garagegt.com/shop/Scripts...dproduct=19478
Sponsored Links
Old 01-23-2008, 11:46 AM
SovXietday SovXietday is offline
My Garage
Send a message via AIM to SovXietday
Default RE: how much hp gain from turbo?
~250ish.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 01-23-2008, 04:03 PM
My Garage
after adding that turbo i could legitly say that i have 250 whp?
Old 01-23-2008, 04:53 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
you are gonna have to get the kit tuned so your motor doesnt blow and the dyno your tuning on will tell you how much hp you have.
__________________
cylinder head guru!
Non Vtec power
Old 01-23-2008, 08:02 PM
My Garage
Quote:
ORIGINAL: 00IntegraLS
No.
You can say it either when you put that power down on the dyno or have track proof that backs up the power.
__________________
Old 01-29-2008, 10:24 AM
RCJr9186 RCJr9186 is offline
My Garage
Send a message via ICQ to RCJr9186 Send a message via AIM to RCJr9186 Send a message via Yahoo to RCJr9186
before you go buying this kit... what exactly are you looking for? a t3/t40e is a pretty big turbo that CAN push you up to 450whp but if you are looking for nothing but a 300whp street ride than you need a diff turbo. the lag in that thing will kill you on the street and course!
__________________
93 Del Sol S - Greddy EVO2 Catback
B18c JDM GSR
Fidanza Prolite 6.98lb Aluminum flywheel.
F1 Racing Stage 2 Clutch
Lightweight pulleys
Old 01-29-2008, 10:35 AM
polo708 polo708 is offline
My Garage
Send a message via AIM to polo708
your 140 stock is to the crank... basically its the power the motor makes by itself. Wheel horsepower is the power that actually makes it to the ground after the loss of power from the drivetrain. FWD cars lose less than RWD cars since there is less distance the power must travel and there is no driveshaft... the average loss for a FWD car is about 12%, RWD is closer to 15%. So for a rough guess take the horsepower rating at the crank and subtract 12% from that. That is a good guess of your whp.
the 120 they are estimating is most likely at the crank so your car stock with that kit running in optimal conditions like they say will put down close to 260hp, 12% of 260 is 31. 260 minus 31 will put you at 229whp. This is an estimate and there are far too many factors to make a true guess but this will give you a round about number. Things like boost levels, altitude, fuel tuning, etc will factor in... tuning and airflow is the key to forced induction.
__________________
-brian
Old 02-01-2008, 02:39 PM
My Garage
Quote:
ORIGINAL: RCJr9186
well ive done searching on this forum and other integra forums and everyone says that t3/t4 turbos are the best for integras..... I plan on using this on the street only... no not illegal drag racing in the streets but you know like when you and your friend are driving somewhere and he pulls up next to you and you race up to a lil over the speed limit and what not.. that kinda thing... what turbo kit do you recommend then?
also I'm thinking about just investing a lot in this car over the next few years and making it as nice as possible..... so thats also why I would want the t3/t4 because in the long run im going to want A LOT of power
Old 02-02-2008, 01:09 AM
bcrichguitars's Avatar
bcrichguitars bcrichguitars is offline
My Garage
How much boost will you be running?
__________________
95 EG - JDM D15B VTEC (LSD Tranny)
75.5mm Vitara Pistons/I-Beam Rods
TD05H 16G Evo III Turbo
Crower St. 2 Turbo Cam/Valve Springs/Titanium Retainers
Old 02-06-2008, 11:00 PM
My Garage
7psi
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
