HondaCivicForum.com
-   General Civic Talk (https://www.hondacivicforum.com/forum/general-civic-talk-16/)
-   -   front and rear strut bars??? (https://www.hondacivicforum.com/forum/general-civic-talk-16/front-rear-strut-bars-59516/)
zoom24 Jan 23, 2008 12:49 PM
Hey anyone here can help a newbie like me regarding the strut bar installaltion???? it will be greatly appreciated!!!
zoom24 Jan 23, 2008 01:01 PM
RE: front and rear strut bars???
ok my car was dropped 2 inches....will it be a problem if i install front lower and rear lower strut bars??? anyone????
Live_4it Jan 23, 2008 01:12 PM
What kind of strut bars do you have? Do you not know where they go or the procedure?
Live_4it Jan 23, 2008 01:18 PM
The ones I got off ebay screw to tighten or loosen to fit right.
That rear one you got to cut a hole in the carpet where your struts are. Make sure you know precisely where they are befor you cut the carpet. Then just take off the 2 smaller nuts on the top not the big one. slide in the bar and tighten real tight.
For the front the same procedure except there is no carpet to cut. Screw off the smaller 2 nuts, loosen or tighten the bar (if need be or it's that style) to fit on. Once screwd tightly on screw the bar around as tight as possibleif loose at all.
If you need more help pm me.
[IMG]local://upfiles/17640/DE3C911779E44EC9B1049DEF7DE7FCBD.jpg[/IMG]
[IMG]local://upfiles/17640/0982EDA0E83048408C7CF9998F7F2D1F.jpg[/IMG]
rice_patrol Jan 23, 2008 01:20 PM
The installation is very simple. Here is a DIY that was done on the forum.
Front
Rear
trustdestruction Jan 23, 2008 02:54 PM
ORIGINAL: zoom24
Are you asking for instructions on the lower strut bars (tie rods)?
Or are you asking if they can go on your car, in addition to instructions for upper strut bars?
zoom24 Jan 23, 2008 03:09 PM
yah coz there was these4 pcs set on ebay....front lower and rear lower struts..... do i really need those ????? is it necessary for that?
zoom24 Jan 23, 2008 03:10 PM
guys im open for opinions of any kind - or + fire it up....
trustdestruction Jan 23, 2008 03:22 PM
I think since you have them you should put them on. I don't think you will have problems being lowered 2 inches, but i'm not entirely sure. They're not completely necessary - you don't need them, but they will improve your handling, and since you have them you should go for it. I don't know how to install the lower ones though,I don't have any... yet.
TheInternet Jan 23, 2008 06:16 PM
Good post, I find it informative...I dont want to sound too stupid here, but how do these bars compare to anti-roll bars, or anti sway bars ? Because I thought they went on the underneath of the car, but these things pictured go in the engine bay, and the trunk...How would anti-roll /anti-sway bars compare with strut bars in the difference in handling ? Thanks !
