Quote:
ORIGINAL: bakertime
You'll need a box unfortunately. The sub that comes stock is an open air sub, meaning it isn't enclosed. It uses the trunk, basically. There are very few companies (if any) that will make one that will fit there and sound good. The bigger problem though, is that to get more hit, you'll need more power, so you're pretty much back to the box, with an amp.
Zach
i didn't get that open air sub concept ....
i move from Pakistan 5 years ago, over there subwoofer introduced that time ... everyone installing on the same place Si has. No concept of putting box in the trunk, awsome sound even using Tapes instead cd's
i will search more to get sub on the factory place.... per
07blksi ... i will look into stealth box.
