Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 02-01-2008, 01:42 PM
tombakers tombakers is offline
Default need to find the fault in the speedo system
how do i go about finding the fault in the speedo system to see whther it is the speed sensor, the wiring or the cluster?
Thanks!
Sponsored Links
Old 02-01-2008, 06:26 PM
RonJ RonJ is offline
HCF Humble Servant
Send a message via AIM to RonJ
Default RE: need to find the fault in the speedo system
See pictures.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Old 02-01-2008, 07:47 PM
addiction2bass addiction2bass is online now
do you have a CEL light on?
if so most likely the speed sensor... if not could be the clusters speedo...
__________________
Old 02-03-2008, 05:14 AM
thnaks for the help guys really helpful, the car doesnt seem to be charging the batteryaswell now for some frustrating reason. all the wiring is plugged in and belt is on. goin to check it for voltage tommoro from the alternator. the car has had a new engine fitted by me recently. the strange thing was it did 600 miles before gettin any problems atall. not sure whether these faults are related, because te speedo went before the aternator stopped working. and the cellight didnt come on when the speedo stopped working. but it does now due to the alternator not working. thank again for the help good diagrams!!
Old 02-03-2008, 06:58 AM
HCF Humble Servant
A failing alternator can trigger the charging light (battery symbol) to turn ON but not the CEL. Therefore, you may get new insights into your problems by retrieving the CEL code(s) as described here:
After you retrieve the code, note it and then clear the ECU. If the CEL turns ON again, retrieve the code to verify that it is the same as before. Troubleshoot any repeated fault code and make appropriate repairs.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
