Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 02-03-2008, 10:35 AM
mikeyg323 mikeyg323 is offline
Default 2 Way Problem
I have a Viper 2 way command start/alarm combo on my 2000 civic cx hatch. It came with the car. Anyway, my passenger door seems to not be opening while the car is running. I have to shut the car off, then unlock it. Why is this? I'm guessing it's a problem involving the 2 way remote starter because it the CX models dont have power locks, but with the Viper it can open. Any suggestions? Thanks all.
Sponsored Links
Old 02-03-2008, 07:35 PM
civicduty96's Avatar
civicduty96 civicduty96 is offline
Default RE: 2 Way Problem
is there a acuator in the pass door.....
__________________
96 civic..t25 turbo...FMIC
jdm sir ll swap..stage 2 ACT clutch
OBX LSD...hondata s300
AEM wide band...ACL race main and rod bearings
JE forged pistons and rings
Eagle H-beam rods...cometic head gasket
GM 3bar map sensor..GM boost seloni
Old 02-03-2008, 09:52 PM
Not sure, what would it look like?
Old 02-03-2008, 11:26 PM
rudedawwg rudedawwg is offline
does your car have automatic door locks... if not then there may not be an actuator in the pass door or it may be bad
Old 02-04-2008, 05:09 AM
Nope, all manual.
Old 02-04-2008, 04:23 PM
what i'm saying is if it unlocks with your viper remote someone put a doorlock actuator in....
__________________
Old 02-04-2008, 08:21 PM
yeah. what duty said
Old 02-04-2008, 10:28 PM
Ok, so does the actuator make it so that you cannot unlock the passenger side door while the car is running? My car locks itself when it's started.
Old 02-05-2008, 07:06 PM
it has ignition lock and unlock on.... its a feature that can be turned off in the features menu on your alarm... tell me the model # and i'll tell you how to turn it off.... you'll need to use your valet button since you probally dont have acsess to a BITWRITER....
__________________
Old 02-05-2008, 09:49 PM
It is a Viper 479V/P/X
it's FCC ID: EZSDEI478
I tried looking for the vallet switch but it's all too confusing :P
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
