Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-03-2008, 02:00 PM
sebdiz sebdiz is offline
Default Break Fluid Leaking
My Break Fluid is leaking and my brake light turns on atleast once every 3 weeks.. as if i have my E-brake pulled... i have to refill the break fluid ever so often so it wont turn on... im wondering what i need replacing.. or what i can patch or how can i fix my brake fluid problem... i have a 93 civic lx.. would replacing the rotors fix this?
Sponsored Links
Old 02-03-2008, 02:46 PM
RonJ RonJ is offline
HCF Humble Servant
Send a message via AIM to RonJ
Default RE: Break Fluid Leaking
You need to locate the leak.
Begin by inspecting the area around the master cylinder where you add brake fluid. You may need to wipe the area clean so as to detect a possible leak.
If the master cylinder is fine, then remove each of the wheels to allow inspection of the front calipers and rear wheel cylinders for a leak.
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/zerothread/1901557
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
