Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 02-05-2008, 12:36 PM
RebornSI RebornSI is offline
Default Which do you like? SC or Turbo
I am not here to ask which one is better or the same old stuff that every one asks. Just want to see what type of members are here and where they stand and there preference.
For me, there is nothing like the sound of a SC. I would take that over and turbo.
Sponsored Links
Old 02-05-2008, 12:59 PM
BX_Civic BX_Civic is offline
Send a message via AIM to BX_Civic
Default RE: Which do you like? SC or Turbo
i wold go turbo, i have had a few turbo cars and i like them alot. Ive never driven in a SC car but turbos are like free power SC is blet driven so will steal some power back just to run it.
__________________
Sitting on 17's not even sure what kind they are..
Little bump in the Trunk but nothing to special..
Pic's of the Car Below
http://obi1kanobi.com/Images/Car/
Old 02-05-2008, 02:00 PM
polo708 polo708 is offline
Send a message via AIM to polo708
its all in what you want... with a supercharger its instant power and there all the time... zero lag. When I launch Im at fill boost in less than a second.
You need to look at the pros and cons and decide what best fits your budget and wants.
If you are looking at overall horsepower for a civic then the answer is simple... get the turbo and quit wasting time. BUT in exchange for the high horsepower you want you will need plenty of parts. Stronger internals, an upgraded fuel system and a serious tune. Downside is that it wont be as reliable as s/c will be. A supercharger kit is pretty close to a bolt on install and their parts arent as complicated as a turbo. With a turbo you are looking at a lot of piping and running oil lines which tend to leak. there is also alot more maintenance involved. Cant install it yourself? Plan on a few thousand dollars alone for most shops to install that thing and a few days at least.
With the supercharger for a civic they commonly come in a roots style which will replace the intake manifold and basicallyt bolt on pretty easily with the exception of possibly running a fuel line. Mine comes with a 5th injector to add fuel, some compensate by larger injectors or just dumping alot of fuel. Maintenance is... well, not really a thought. Other than your belt wearing a bit faster they are internally oiled and that gets changed about once every 100,000 miles. No piping, no iol lines to be tapped, no real worry of a boost leak. If there is its a simple line and a minor fix. Also, the while of a supercharger at wide open throttle is just music to my ears. Dont know what it sounds like?... search videos of Mustang Cobra for the best sounds. Install is alot more simple compared to a turbo and can be done in about 3 hours at best. The norm is alittle longer, but thats my record haha.
If you plan to stay under 250hp then its a toss up, well for me Id take a supercharger any day but for the sake of argument there really isnt too much of a difference. Low boost on both are great and pretty similar. If you plan to make it a monster and run alot of boost then go turbo and plan on spending cash for a few broken, weak parts.
When you get into centrifugal superchargers its a bit of a different story, especially on V8's. My above argument is with Civics and 4 cylinder cars in mind. Simply, a centrifugal s/c is a turbo, but the wastegate is replaced by a pulley. Fastest street legal S197 Mustang right now is supercharged with a centrifugal blower... not turbo charged.
__________________
-brian
Old 02-05-2008, 05:50 PM
^wow that was alot. I just asked for your preference and you gave me a whole essay lol. Still enjyed reading it and i am with you on the SC bandwagon. That whine is sexy!!!!!!!
Old 02-05-2008, 06:02 PM
SovXietday SovXietday is offline
Send a message via AIM to SovXietday
Eh, I kinda miss my SC whine but the power was complete **** compared to what I'm making now.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 02-05-2008, 07:29 PM
yeah, power isnt as good overall with the smaller roots/twin-screw superchargers. Not sure of the JR chargers with the civic, but the TRD s/c I have is just a rebadged Eatom M45. Many are upgrading the internals themselves... swaping the impellers with larger ones from an Eaton M65. Average gain is 30-40hp at 8 psi and a smoother powerband.
Problem with the JR supercahrger and mine in stock form is the heat that is generated. The stock pulleys are made at near peak performance. You can go smaller on the pulley to gain boost pressure, but at the same time you are creating more heat. At a certain point you are just building boost with no added power. Intercoolers and water injection systems help to a point, but the small screws from a blower used in our cars can only move so much air. Roots/twin-screws basically just force air into the chamber, a turbo/centrifugal supercharger actually compress air.
__________________
-brian
Old 02-05-2008, 11:33 PM
didder's Avatar
didder didder is offline
if you like the constant sound of a whine just go with a smaller turbo like a td04 or a t25 and it will zing all day long for you [8D]to top it off you end up getting the added sound of a bov
smaller turbos will limit you to under 250whp to though so yea, its all up to your preferance
__________________
285Whp and 225wtq on 15psi
And Running Like A Turd
Old 02-06-2008, 10:07 AM
a supercharger and "small" turbo sound completely different.
And there are plenty of small turbos that will net you well over 250hp. I was referring to small/average boost levels.
__________________
-brian
Old 02-06-2008, 04:49 PM
Quote:
ORIGINAL: polo708
I always wondered about that. hmmmmm. I have not heard too much promissing things about the centrifugal SC. Only really good a high rpm or thats where it make max boost something like that i heard and cost mucho $$$. I like the whole concept behind it... right now its a toss up between the two for me. Not looking to make mad power...not racing it... not a drag car... dont want 14mpg cause i cant keep my foot off the gas... I just like the tq feeling lol. Something that reminds me of the planes that i fly. Does it whine the same or sounds more like a turbo.
Old 02-06-2008, 05:48 PM
Centrifugal SCs are pretty boring really. They really don't make a lot of power and the expense of them is unreal for what you're getting. I have a friend with a full built B16 (like 10K+ in engine work) and he's making 303whp... lol.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
