well, this is an old post, but i'll give some insight into the subject. plus i'm bored at work, lol.
i went for obd0-obd1. i know that when i had to do that, i had to use the obd1 distributor (dizzy). basically from what i understand, you have to use a dizzy for whatever obd# ecu you're using.
obd2 ecu's can't be chipped. they can have a piggy back system though (that's when you have a system that plugs in where the ecu and ecu harness connect. this system then reconfigures everything to how you want it. it's a lot more expensive too)
the p2p ecu should plug right in. i'm not sure, but it is obd2 which is what you have. usually they're just plug and play.
the part number you wrote "37820-P2P-A _ _" is right.
"37820" is always the same
"P2P" is the ecu code
"A _ _" is explained this way. first letter = country of orgin
J = Japan
C= Canada
A=USA
G=Europe
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
L = California emissions or typically high altitude states as well.
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
to go to obd1, you need to buy an ecu jumper harness that goes from obd2 to obd1. they're easy to find and not too expensive. the p28 ecu's aren't very expensive. i bought one about 2-3 weeks ago for $70. you just have to look for them long enough and you can find deals
an aftermarket intake will help with better airflow, but you won't see a dramatic increase in power. remember to replace the headers and exhaust or else it's not going to help you. making the intake less restricted doesn't do anything if the exhaust is still restricted
anyways, you probably did the swap already but i was bored and came across the posting
