Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 07-26-2004, 05:44 PM
SI_racer SI_racer is offline
Send a message via AIM to SI_racer Send a message via Yahoo to SI_racer
Default si si racing head
hey guys ! does anyone know where i might be able to get a hold of a new racing head for my 99 si ?? thanks for ur help ! just so we r not confused ! (not header ) the head ) thanks
__________________
99 civic si / obx exhaust / tokico springs & struts / 17' MB motorsport rims / kumo tires /carbon fiber e-brake and shift knob / autometer tach / tweeker blinkers
Sponsored Links
Old 07-26-2004, 07:20 PM
NTX NTX is offline
Default RE: si si racing head
Port, polish, and cams and you have your own....
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 08-05-2004, 05:24 PM
2000Si 2000Si is offline
Quote:
ORIGINAL: ntxmotorsports
:thumbsup:
The cheapest route would be to go with Skunk2 stage two cams, retainers, valve springs, etc... right around 1400. Then a port and polish.
Or you could TRY to find an integra type R head. Same head as on the b16, just more agressive cams, and it breathes better. (among a few other smallish details)
your best bet is what ntx said.
Old 08-09-2004, 08:48 PM
lilol89crx lilol89crx is offline
Send a message via AIM to lilol89crx Send a message via Yahoo to lilol89crx
Quote:
ORIGINAL: 2000Si
:thumbsup:
yup same castings. differences being cams, and a port job .
__________________
89 crx sold.....91 hatch new project for turbo ls
<br />90 crx dx-daily beater
<br />04 suzuki gsxr750-sunny day beater
<br />83 rx7-pos sittin in the yard
01 yamaha r6 stunt bike-pos that i dont care about
Old 08-10-2004, 01:38 AM
sacicons sacicons is offline
the type r head also has dual valve springs on both the intake and exhaust sides, as well as lighter valves and retainers. thats why it can rev higher than the b16a head. not a bad upgrade, but they are pretty expensive. also remember that you will also have the stock head to sell.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 08-10-2004, 08:40 PM
Quote:
ORIGINAL: sacicons
Bump up the fuel shut off and a b16a2 will rev to 8400-8500 easily, but it's not going to give you much of a gain on the stock cams/valvetrain.
Old 08-10-2004, 10:14 PM
have fun. reving a stock b16a to 8500 will float the valves and toast the motor. you might get away with it for a while, but not long. you'd better upgrade the valve springs first.
__________________
Quote:
ORIGINAL: Forty04
Old 08-10-2004, 10:17 PM
to answer your Q, SI_Racer, what are your power goals with the new head? Budget?
__________________
Quote:
ORIGINAL: Forty04
Old 08-11-2004, 12:19 AM
Quote:
ORIGINAL: sacicons
The B16a2 will be fine up to 8500 rpm... stock the fuel cutout is 8200. Another 300 rpm isn't going to do that much to the motor. But I do agree, it is wiser to upgrade the valve springs and retainers.
Old 08-11-2004, 10:18 PM
but do the stock cams even produce power at that high of an rpm? ive never seen the dyno plots of the stock b16 cams but im sure it doesnt produce much power that high. ive got the cam specs somewhere for all b series vtec heads......somewhere.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
