Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 04-25-2005, 02:35 PM
05CivicLX 05CivicLX is offline
Default Need a Hi Output Alt????
Getting ready to put Pioneer Premier headunit, dvd player, two screens in the headrest, premier 500 watt amp, and two premier 12 ALCC subs. I plan on running a 4 gauge wire system to a stinger 1.2 farad cap. I'm still running honda's stock alternator, but did come across a 170 alternator; is upgrading the alt something that I need to do or will the cap be enough to handle all the power request?
__________________
'05 LX - 5spd (D17A1)
Injen Short Ram Intake
Sponsored Links
Old 04-25-2005, 02:37 PM
LEVIII LEVIII is offline
Default RE: Need a Hi Output Alt????
You are only running 1 amp? If so the alternator will not be needed
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Old 04-25-2005, 03:24 PM
yes, one amp; approx 500 - 600 watts. so the cap will be enough for the system? what about the dvd player and screens? do i connect them to the battery or the cap?
__________________
Old 04-25-2005, 03:56 PM
Roost3r Roost3r is offline
Send a message via AIM to Roost3r
u wont need a new alt unless your really doin a system..like 3 or 4 amps.. i mean..anthing from caps. to a yellow top batt. will be more usefull other wise
Old 04-25-2005, 04:10 PM
ok what set-up would you suggest?
__________________
Old 04-25-2005, 04:15 PM
cap.
Old 04-25-2005, 04:24 PM
and have the amp, dvd, and screens running off the cap; or just have the cap holding the amp and running the dvd system off the battery?
__________________
Old 04-25-2005, 04:28 PM
jwsimons jwsimons is offline
if your worry'd about power consumption agood thing might be an ammeter/voltmeter. if you use any of your equipment when engine is off, you will know when you need to shut down or start your car. no alternator or power cap does that.
__________________
getting there is half the fun, do it yourself
Old 04-25-2005, 05:48 PM
not planning on running anything when the engine is off, but after awhile of running the stereo system I don't want the amp to start cutting out again or sounding like mush like when they were in my truck.
__________________
Old 04-25-2005, 10:40 PM
Pete Pete is offline
Send a message via Yahoo to Pete
get a cap and an optima yellow top battery........ull be in business
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
