Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 02-21-2008, 02:58 PM
raz raz is offline
Default 2 inch drop on springs and stock shocks
I have searched and never got a real clear answer. If I just do a 2 inch drop all around just srpings on stock shocks will I need to get new shocks? if so I got some in mind. also do i need to purchase all 4 shocks or just 2...every place i se sells them for about 80 each and im trying to stay within my 300 budget.
I jusy want something for a DD and still have some good performance aspects.
Thanks
Sponsored Links
Old 02-21-2008, 03:06 PM
nebrown1 nebrown1 is offline
Default RE: 2 inch drop on springs and stock shocks
you should do all 4 shocks or your stock ones mit blow out. you sure you want to do a 2 inch drop i just did a 1.8 in the front and 1.5 in the back. and my car hit's the ground
Old 02-21-2008, 03:08 PM
raz raz is offline
ok cool. really!? wow and thats my concern. I have a body kit and really dont wann mess it up.. but 2 inches would fill the gap better...how big is your gap?
Old 02-21-2008, 03:13 PM
civicexracer civicexracer is offline
yeah u'll want to replace the shocks. easier and cheaper to just do it all at once. u'll need all 4.
__________________
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
Old 02-21-2008, 03:15 PM
raz raz is offline
Ok for 7thgens I heard ground control is good spring..
I have an offer for 100$ springs..dropzone..are they ok? and whats a good shock to get thats not freakin 80a piece..keep in mind my 300-350 limit please
Old 02-21-2008, 03:39 PM
Ground Control makes coilovers and they use Eibach springs on them. their also quite a bit more expensive then ur run of the mill springs. dropzone's are junk, for an extra ~$100 u can get Tein S-Techs brand new. probably the cheapest decent shocks u'll find would be the Tokico blues or the KYB GR2's. parts are more expensive for ur generation so u may want to up ur budget a bit.
__________________
Old 02-21-2008, 03:47 PM
raz raz is offline
so what would you say would be a great DD setup..around ok lets say tops 600..perferable less tho
Old 02-22-2008, 11:34 AM
raz raz is offline
bump
Old 02-22-2008, 06:27 PM
SITNLOW97 SITNLOW97 is offline
Send a message via AIM to SITNLOW97
If u have a kit on and its urr dd i would go with tein s tech's and tokico struts....thats gonna run u prolly about 500 on ebay just make sure there the real ones and not fake...but keep in mind u will need a camber kit if u dont already have one...
__________________
Old 02-22-2008, 06:28 PM
But if ur on a really tight budget u could get by with just springs on stock struts only if u getn tein springs...
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
