RE: Where do i put it?
the speedometer cable goes in the upper rear of the transmission. behind the starter. you just put it in the hole and put the retaining clip on.
the ball joint and axle are easy. take out the two bolts under the hood for the upper control arm, and unbolt the ball joint itself from the steering knuckle.put in the new control arm, or have a new ball joint pressed in.
for the axle, take off the 32 mm nut on the axle, and unbolt the steering knuckle and the strut from the lower control arm. then you should be able to move the knuckle out of the way to pull the axle out of the tranny.
__________________
1969 chevelle 350 4 speed
1990 civic hatchback dx b18b 5 speed
1990 civic hatchback dx d15b2 turbo 4 speed
1989 civic hatchback si 5 speed
