Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 07-27-2004, 09:53 AM
niteryder niteryder is offline
Default valve springs
do performance valve springs add hp or do they just raise rpm's?
__________________
a vtec a day will keep the doctor away
Sponsored Links
Old 08-03-2004, 05:20 PM
NTX NTX is offline
Default RE: valve springs
They won't raise your rpms but perform better at higher rpms. You wont see and hp increase either. They may be a bit lighter than stock.....but thats about it.
__________________
Apexi Boost Gauge, Apexi Meter Control Unit, RMR C/F Gauge Pod, Blitz Fatt DC III, Rexpeed Apex VG
Old 08-03-2004, 05:28 PM
sacicons sacicons is offline
high performance valve springs are part of a whole package that you should do all together. if you replace the valves, springs, and retainers, then yes, it will raise your redline( I assume thats what you meant by rpms) and in itself, you will see marginal or no hp gains, as the stock cams will choke out the motor at higher-than-stock RPMs. the power is found in high performance cams, hi-po valves, springs, and retainers, along with a computer mod that will allow you to move your rev limiter up to utilize the bigger cams. the springs are a means of making more power, not a power mod in themselves.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
